Is there a SUPER fast way to see all revisions someone has done?
From EE Slack's avatar
From EE Slack
Looking for a way to see all entry revisions by a particular user.
Interested in learning more solutions or want to get to know other EE users? Read more about joining the slack here! Join Our Slack!
dougblackjr's avatar
dougblackjr
dougblackjr's avatar dougblackjr
With entry revisions enabled (which now I will ALWAYS do), I ran this query to find them:
SELECT entry_id FROM exp_entry_revisions WHERE author_id = X (x being the ID of the user).
Thanks for your help!
From EE Slack
As was pointed out in Slack, you can do this with a query, but only if you have entry versioning enabled across all of the relevant channels.
You can try the following query in the Utilities- SQL Query Form:
SELECT * from exp_entry_versioning where author_id = x
Where ‘x’ is the member id you’re interested in.
For something a bit easier to read, you could use the Query module- you may need to install it first.
{exp:query sql="
SELECT * from exp_entry_versioning where author_id = 'x' "}
    {author_id} {channel_id} {version_date format="%D, %F %d, %Y - %g:%i:%s"}
{/exp:query}
? 2
