Can we use ENV variables in templates to do conditionals?
From EE Slack's avatar
From EE Slack
about 2 years ago
Interested in learning more solutions or want to get to know other EE users? Read more about joining the slack here! Join Our Slack!
Jared Chesebro's avatar
Jared Chesebro
about 2 years ago
Jared Chesebro's avatar Jared Chesebro
In order to add ENV variables to your templates you’ll first need to add them to your .env.php file (this file should sit next to your system directory):
# .env.php
ENV=production
Once you’ve defined your variables you need to add them to ExpressionEngine’s config:
// config.php
$global = [];
// Add your variables here
$global['global:env'] = $_ENV['ENV'];
global $assign_to_config;
if (! isset($assign_to_config['global_vars'])) {
    $assign_to_config['global_vars'] = [];
You should now be able to access your global variables in your templates:
{!-- Template --}
{global:env}
Laverneleg's avatar
Laverneleg
Laverneleg's avatar Laverneleg
Great sharing, amazing, thank you so much.
