How to custom order entries easily?
From EE Slack's avatar
From EE Slack
I have a page of dining locations and all the locations are stored in a channel. In the template, if you are on the “Dining” page it just lists them alphabetically Client wants to be able to put them in a particular order… anyone have a way of ding this on page that doesn’t involve relationship fields ?
Join our Slack channel!
From EE Slack
You can order the display of entries on the frontend by just about any custom field, or use an add-on like Low Reorder to drag and drop multiple ordering options.
Daliz's avatar
Daliz
Daliz's avatar Daliz
You can use Low Reorder to do this. Your client can drag and drop the order he diseres
Andrés Molina's avatar
Andrés Molina
Andrés Molina's avatar Andrés Molina
In FrontEnd context, you can Try reefine
https://github.com/Patrick64/reefine
