Clone an Entry
Kub22ISD's avatar
Kub22ISD
Kub22ISD's avatar Kub22ISD
I successfully cloned 22 entries yesterday and 15 more this morning. Then I started to get the following error “Cannot Create Entry - We were unable to create this entry, please review and fix errors below.” I checked all tabs and there do not seem to be any errors below to fix. I get the same error on every subsequent entry I try to clone. Please advise.
Hrmm, this one seems odd… Just to confirm, is this in EE 7.x?
Kub22ISD's avatar
Kub22ISD
Yes, 7.2.17 Pro.
I was able to successfully clone 22 entries on one day and another 15 the next day. Then I started getting this error on all new attempts. I have looked on every tab and see no errors to fix.
We are also having an issue trying to use the grid field (for the first time) where we can add only so many items before it will not let us add others.
Really struggling to get things done with EE.
Hi Kub,
Thanks for posting this.
For starters I’d recommend updating to the newest version of EE 7.3.6.. Theres a LOT of bug fixes between 7.2.17 and the current version.
If you look at the JS console in your browser do you see any errors?
It also might be worth joining Slack and mentioning the issue there as well.
I’ll bring this up in our internal slack to see if anyone else has ideas / suggestions.
-Tom Jaeger
Probably should have mentioned.. I’m wondering about the JS console errors, as this could be the cause of both of your issues.
Has there been any new add-ons installed as well?
-Tom Jaeger
Kub22ISD's avatar
Kub22ISD
Hi Tom - we just upgraded our environment to the latest release (7.3.7 from today) and are still seeing these issues. No luck finding any errors in the console either
Not sure why your running into this as a whole.. to trouble shoot if further, we would need a support ticket open and likely have to login to take a peek).
Might not be a bad idea to bring it up in Slack as well to see if anyone else has an idea.
