Select a group for a channel - but fields missing
pm1625637's avatar
pm1625637
3 years ago
pm1625637's avatar pm1625637
Even if you selected a group you must select fields that come with it.
3 years ago
Just ran a quick test on this, and I’m not able to replicate. Just to confirm did you add the fields to the field group?
pm1625637's avatar
pm1625637
3 years ago
Yes, fields are relate to group. (edit) Sorry i can’t add image on the forum anymore. Don’t know why. It is sad , it help me to explain condition. Anyway.
3 years ago
Hrmm.. let me run a few more tests… what field types are those?
pm1625637's avatar
pm1625637
3 years ago
1 Rich Text Editor {Page Content}
1 Text input {subtitle}
3 years ago
Hrmm… that’s the two I tested with already. Can you double check to make sure the fields are in the field group real quick? I’ll also create a quick video to send over to make sure we’re on the same page.
3 years ago
I made a quick video… Am I testing the right thing?
Field Groups
pm1625637's avatar
pm1625637
3 years ago
TEST
3 years ago
Thanks for posting this. Looks like a but I was able to replicate.
Fields that are NOT assigned to a group show up in an empty group when filtering fields by the empty field group, using the dropdown filter on the fields page.
I went ahead and created a github issue for this as well
3 years ago
So there is a bug here… We’ll work to get it fixed ASAP… However if you edit the field group (pencil icon next to it on left side hand side) you should be able to assign the fields and have it work as intended for now.
Thanks for taking the time to work through this with us!
-Tom Jaeger
P.S. There’s over 7,700 of us in Slack if you want to join us there! Messages in the forum do cross post there as well!
3 years ago
This bug has been fixed. It should be shipped in our next release (planning for Monday or Tuesday of next week).
If you would like to check it out or manually fix it, heres a link to the fix on github.
-Tom Jaeger
