How to use {exp:query} results in {exp:channel} parameter?
shbchk's avatar
shbchk
5 years ago
shbchk's avatar shbchk
Since i can not retrieve {parents} from grid field, i am trying to find simplest workaround.
This works great:
{exp:channel:entries channel='channel-one' entry_id='
        <?php
            $servername = 'blabla';
            $username = 'blabla';
            $password = 'blabla';
            $dbname = 'blabla';
            // Create connection
            $db = mysqli_connect($servername, $username, $password, $dbname);
            // Check connection
            if (!$db) {
            die("Connection failed: " . mysqli_connect_error());
            $url_pieces = explode("/", $_SERVER['REQUEST_URI']);
            $sql = 'SELECT parent_id FROM exp_relationships WHERE child_id = '.$url_pieces[2].'';
            $result = mysqli_query($db, $sql);
            while($row = mysqli_fetch_array($result, MYSQLI_NUM)) {
                echo $row['0']."|";
    ' disable='categories|member_data|pagination|category_fields'}
This works great also and produces little more total_queries:
            <?php
                $pieces = explode("/", $_SERVER['REQUEST_URI']);
                $sql = 'SELECT parent_id FROM exp_relationships WHERE child_id = '.$pieces[2].'';
                $query = ee()->db->query($sql);
                if ($query->num_rows() > 0)
                    foreach($query->result_array() as $row)
                        echo $row['parent_id']."|";
But i can not get same result when i’m trying to use {exp:query}, it shows me nothing or error.
Here is what i’ve tried:
{parents_ids} Template Partial content:
{exp:query sql="SELECT parent_id FROM exp_relationships WHERE child_id = '{last_segment}'" backspace="1"}{parent_id}|{/exp:query}
Tempate code:
{exp:channel:entries channel='channel-one' entry_id='{parents_ids}' disable='categories|member_data|pagination|category_fields'}
This returns nothing.
Is there anyway to do what i am trying to do without php in templates?
(ExpressionEngine® CMS 5.3.2, PHP 7.3.15)
5 years ago
We just pushed a fix for this to the repo and it will be in the next release.
https://github.com/ExpressionEngine/ExpressionEngine/issues/432
