Relationship parents does not work
shbchk's avatar
shbchk
5 years ago
shbchk's avatar shbchk
Please, help me understand.
Here is my structure:
› CHANNEL_ONE
-- {title}
-- {url-title}
-- {channel-one-grid}
---- {field1}
---- {channel-two-relationship} *(multiple)*
---- {field2}
---- {field3}
› CHANNEL_TWO
-- {title}
-- {url-title}
-- {ch2field1}
-- {ch2field2}
When i’m on a CHANNEL_TWO entry page, how i can show all entries from CHANNEL_ONE that listed this CHANNEL_TWO entry as related?
Here is my current code that does not work:
<body>
{exp:channel:entries channel='CHANNEL_TWO' limit='1' require_entry='yes' disable='categories|member_data|pagination|category_fields'}
{title}
etc
{exp:channel:entries channel='CHANNEL_TWO' require_entry='yes' disable='categories|member_data|pagination|category_fields'}
{parents field='channel-one-grid:channel-two-relationship'}{parents:title}{/parents}
</body>
What i get:
Notice
Undefined index: channel-one-grid:channel-two-relationship
ee/legacy/libraries/relationship_parser/Tree_builder.php, line 455
Severity: E_NOTICE
Warning
Invalid argument supplied for foreach()
Severity: E_WARNING
Warning
Cannot modify header information - headers already sent by (output started at ee/legacy/core/Exceptions.php:120)
ee/EllisLab/ExpressionEngine/Boot/boot.common.php, line 493
Severity: E_WARNING
shbchk's avatar
shbchk
5 years ago
PHP Version 7.3.15
MySQL 5.6.44-86.0
ExpressionEngine® CMS 5.3.2
shbchk's avatar
shbchk
5 years ago
Also tried this code (and its variations):
{exp:channel:entries channel='CHANNEL_TWO' disable='categories|member_data|pagination|category_fields'}
{channel-one-grid}
{channel-one-grid:channel-two-relationship:parents field='channel-one-grid:channel-two-relationship'}{parents:title}{/channel-one-grid:channel-two-relationship:parents}
{/channel-one-grid}
Getting this error:
Fatal error: Uncaught Error: Call to a member function getValues() on null in /home/s/eesystem/ee/EllisLab/ExpressionEngine/Model/Channel/ChannelEntry.php:1189 Stack trace: #0 [internal function]: EllisLab\ExpressionEngine\Model\Channel\ChannelEntry->getModChannelResultsArray() #1 /home/s/eesystem/ee/EllisLab/ExpressionEngine/Library/Data/Collection.php(86): call_user_func_array(Array, Array) #2 [internal function]: EllisLab\ExpressionEngine\Library\Data\Collection->EllisLab\ExpressionEngine\Library\Data\{closure}(Object(EllisLab\ExpressionEngine\Model\Channel\ChannelEntry)) #3 /home/s/eesystem/ee/EllisLab/ExpressionEngine/Library/Data/Collection.php(245): array_map(Object(Closure), Array) #4 /home/s/eesystem/ee/EllisLab/ExpressionEngine/Library/Data/Collection.php(94): EllisLab\ExpressionEngine\Library\Data\Collection->map(Object(Closure)) #5 /home/s/eesystem/ee/legacy/models/channel_entries_model.php(25): EllisLab\ExpressionEngine\Library\Data\Collection->__call('getModChannelRe...', Array) #6 /home/s/shb in /home/s/eesystem/ee/EllisLab/ExpressionEngine/Model/Channel/ChannelEntry.php on line 1189
shbchk's avatar
shbchk
5 years ago
And even this one:
{exp:channel:entries channel='CHANNEL_ONE|CHANNEL_TWO' disable='categories|member_data|pagination|category_fields'}
    {channel-one-grid}
        {channel-one-grid:channel-two-relationship}
                {channel-one-grid:channel-two-relationship:parents:title}
        {/channel-one-grid:channel-two-relationship}
    {/channel-one-grid}
5 years ago
I’m not surprised the field parameter doesn’t take a grid field. Does it work if you leave that out?
{parents}{parents:title}{/parents}
There’s a reported bug using Parent fields with file grids, which share a lot of code. (https://github.com/ExpressionEngine/ExpressionEngine/issues/432). If it fails, I think the best option is to add a comment there and stay subscribed.
shbchk's avatar
shbchk
5 years ago
Thank you, Robin Sowell!
Trying to come up with workaround, started new forum topic: https://expressionengine.com/forums/topic/252782/how-to-use-expquery-results-in-expchannel-parameter
shbchk's avatar
shbchk
5 years ago
Is there a chance EE to fix this bug? Or i need to think of alternatives?
5 years ago
Quick update on this one, we just pushed a fix for this to the repo and it will be in the next release.
? 1
Edina2020's avatar
Edina2020
5 years ago
Edina2020's avatar Edina2020
This post is so helpful!
celinedion's avatar
celinedion
3 years ago
celinedion's avatar celinedion
Thanks a lot, I updated and it works fine.
