What is wrong with this plugin code? Variable not being read in SQL query
Chad Crowell's avatar
Chad Crowell
17 years ago
Chad Crowell's avatar Chad Crowell
This code works fine as shown, echoing the $member_id value to the screen, and then running the following query. Notice, though, that the member_id in the SQL statement is hard coded as 1.
When I change the SQL to say member_id = ‘$member_id’ , which is how I want it to work, the query returns no rows and the die statement is executed.
However, as I said, I know the $member_id variable is valid because it is printing correctly to the screen (member 64, in my test case).
And I know the SQL statement works just fine when hard coded with 1 in it.
Ideas?
global $TMPL, $DB, $REGX;
        $member_id        = $TMPL->fetch_param('member');
        $name            = $TMPL->fetch_param('name');
        $type            = $TMPL->fetch_param('type');
        if (!$member_id) {
            die('no member_id');
        if (!$name) {
            die('no name');
        $this->return_data .= $member_id;
        //Get the user's information from the members table
        $query = $DB->query("Select username, screen_name, email from exp_members where member_id = '1'");
                if ($query->num_rows == 0) {
                    //does this member_id exist?  This is weird...
                    die('no member ID');
                } else {
                    $username = $query->row['username'];
                    $screen_name = $query->row['screen_name'];
                    $email = $query->row['email'];
Mark Bowen's avatar
Mark Bowen
17 years ago
Hi Chad,
I don’t know what your plugin tag code looks like as I can’t see what it is called but are you definitely making sure to do this :
{exp:your_plugin_name member="{member_id}"}
Answer here…
{/exp:your_plugin_name}
instead of possibly :
{exp:your_plugin_name member_id="{member_id}"}
Answer here…
I just ask as I noticed that you have name and type in your parameters but then you have placed in your code member instead of member_id. Just wondering if you were possibly placing the parameter in the plugin code as member_id perhaps and then the plugin is expecting a parameter called member?
Just a thought though.
The other question would be how are you sending the member / member_id to the plugin? In other words how is the plugin getting hold of the number? Is this plugin placed within a weblog tag or something else?
Best wishes,
Mark
Chad Crowell
17 years ago
Hi Mark-
Here is the call:
{exp:member_update_notification member="{member_id}" name="{screen_name}" type="{segment_3}"}
As I said, the $member_id variable IS getting the data correctly, because the $this->return_data code does print the correct member_id to the web page.
Below is the whole plugin. I changed the die code to be more accurate, but it still fails there at the first SQL command. I also updated the SQL command to show you how it should look.
<?php
 File: pi.member_update_notification.php
 Purpose: Send email to church office on update of user account
$plugin_info = array(
                        'pi_name'            => 'Member Update Notification',
                        'pi_version'        => '1.0',
                        'pi_author'            => 'Chad Crowell',
                        'pi_author_url'        => 'http://webinception.com/',
                        'pi_description'    => 'Send email to church office on update of user account',
                        'pi_usage'            => Member_update_notification::usage()
class Member_update_notification {
    var $return_data;
    /**  Do it
    function Member_update_notification()
        if (!$member_id) {
        if (!$name) {
            die('no name');
        //$this->return_data .= $member_id;
        $query = $DB->query("Select username, screen_name, email from exp_members where member_id = '$member_id'");
                    die('SQL query did not work...');
                } else {
        //Get the entry_id for the member's profle, if it exists
        $query = $DB->query("Select entry_id from exp_weblog_titles where author_id = '$member_id' AND weblog_id = '9'");
                    //this member doesn't have a member profile
                    $profile = 0;
                } else {
                    $profile = 1;
                    $profile_id = $query->row['entry_id'];
Chad Crowell
17 years ago
//Start our email content
        $email_msg = "Website member $screen_name has recently updated his/her profile. Below is their  profile information, which you can compare with what you currently have on record to find changes.\n\n";
        $email_msg .= "Name: $screen_name\n";
        $email_msg .= "Email: $email\n";
        $email_msg .= "\n";
        //if there is a profile that was updated, get the data within it
        if ($profile == 1) {
            $query = $DB->query("Select field_id_45, field_id_46, field_id_47, field_id_48, field_id_49, field_id_50, field_id_51, field_id_52, field_id_53, field_id_54, field_id_55 from exp_weblog_data where entry_id = '$profile_id'");
                        //that would be really weird...
                    } else {
                        $first = $query->row['field_id_45'];
                        $last = $query->row['field_id_46'];
                        $add1 = $query->row['field_id_47'];
                        $add2 = $query->row['field_id_48'];
                        $city = $query->row['field_id_49'];
                        $state = $query->row['field_id_50'];
                        $zipcode = $query->row['field_id_51'];
                        $phone = $query->row['field_id_52'];
                        $phone2 = $query->row['field_id_53'];
                        $bd_month = $query->row['field_id_54'];
                        $bd_date = $query->row['field_id_55'];
            //Amend more info to the email
            $email_msg .= "Address:\n";
            $email_msg .= "$add1\n";
            if ($add2) {
                $email_msg .= "$add2\n";
            $email_msg .= "$city, $state, $zipcode\n";
            $email_msg .= "\n";
            if ($phone) {
                $email_msg .= "Phone Number(s):\n";
                $email_msg .= "$phone\n";
            if ($phone2) {
                $email_msg .= "$phone2\n";
            $email_msg .= "\n";
            if ($bd_month != "Month" && $bd_date != "Date") {
                $email_msg .= "Birthday: $bd_month $bd_date\n";
        $email_msg .= "\nThank You!";
        //Construct an email and send it to the church office
        if ( ! class_exists('EEmail'))
            require PATH_CORE.'core.email'.EXT;
        $email = new EEmail;
        $email->wordwrap = true;
        $email->mailtype = 'text';
        $email->from('[email protected]');
        $email->to('[email protected]');
        $email->bcc('[email protected]');
        $email->subject('Member contact information update notification');
        $email->message($REGX->entities_to_ascii($email_msg));
        $email->Send();
    /* END */
//  Plugin Usage
// This function describes how the plugin is used.
//  Make sure and use output buffering
function usage()
ob_start();
Ask Obi Wan, he will tell you how this works.
<?php
$buffer = ob_get_contents();
ob_end_clean();
return $buffer;
/* END */
// END CLASS
Chad Crowell
17 years ago
Ah dumb me- should have been using the session class the whole time… fixed.
Mark Bowen's avatar
Mark Bowen
17 years ago
Hi Chad,
Sorry I hadn’t been able to reply to this as I have come down with severe flu and stuck in bed as I write this. :down:
Glad you have it sorted now though.
Best wishes,
Mark
