BK Template Editor v1.0
bkuberek's avatar
bkuberek
17 years ago
bkuberek's avatar bkuberek
This is an implementation of Christophe Dolivet EditArea into Expression Engine’s template editor.
This extension ads source code highlighting and extends the editing capabilities of EE’s template editor.
Festures: Syntax Select Dropdown Font-size Select Dropdown Insert Entities Popup Search and Replace Go to line Undo/Redo Toggle Readonly mode Insert {embed} button Insert {weblog} button
Since I don’t have a documentation site yet, this shall be the documentation page.
Download BK Template Editor v1.1 here: http://bkuberek.com/downloads/ee/bk_template_editor-v1.1.zip http://bkuberek.com/downloads/ee/bk_template_editor-v1.1.tgz
Requirements: Christophe Dolivet EditArea (This extension ships with EditArea 0.7.2.3.)
Installation:
Open the downloaded archive. Copy bk_template_editor/scripts/edit_area to your EE installation directory (default is /scripts/edit_area). Copy bk_template_editor/system/extensions/ext.bk_template_editor.php to your extensions directory. Copy bk_template_editor/system/language/english/lang.bk_template_editor.php to your language directory.
Enable the extension via the EE extension manager. Open the extension’s settings page and edit accordingly.
Update:
Backup settings and disable the extension if you already have it. Replace all files with the new ones. Reactivate the extension. For EditArea Updates visit: cdolivet.net
Change Log: v1.1 download : Added new settings for inputting custom javascript and buttons. Default buttons: Readonly/Editable, insert {embed}, insert {weblog}. v1.0 download : basic implementation of EditArea
Useful Links: EditArea Documentation Configuration Reference
Similar Extensions: Gabriel’s CM Template Editor extension. wlvrn’s Template Editor extension.
Gabriel's avatar
Gabriel
17 years ago
Gabriel's avatar Gabriel
You are missing something 😉 http://ellislab.com/forums/viewthread/56223/ http://www.caleydon.com/expressionengine/template-editor/
bkuberek's avatar
bkuberek
17 years ago
oh no! you had done it before me. I looked in the extensions for it and couldn’t find it. So i threw this together. It works for me what is it that I am missing?
I intended to add the Syntax Drop Down, but now I am not gonna bother anymore. I’m just going to check your extension out. I wish I had found it before so I wouldn’t spend a few hours on it yesterday.
Thanks for the heads out.
Gabriel's avatar
Gabriel
17 years ago
I found another one 😉 http://ellislab.com/forums/viewthread/42923/
bkuberek's avatar
bkuberek
17 years ago
lol, classic
