FoxEE upgrade prevents EE control panel access
Mike Young's avatar
Mike Young
17 years ago
Mike Young's avatar Mike Young
I updated my foxee module on my site to the latest build and I instantly lost access to my EE control panel. I basically just see a blank white page. The front end of both the sites on my MSM installation worked fine but I could no longer access the EE control panel. Sooo…I ended up reverting Foxee to the previous build and now I’m getting this when I try to go to my control panel:
Warning: call_user_func_array() [function.call-user-func-array]: First argument is expected to be a valid callback, 'Foxee_extension::add_jquery' was given in /home/mysite/public_html/ee/system/core/core.extensions.php on line 262
Anyone have any ideas on how to solve this issue?
hildreth's avatar
hildreth
17 years ago
hildreth's avatar hildreth
I am guessing that there is still some database fields or tables left over from the upgrade. Use a mySQL manager and look under ext_modules table and see if there are any foxEE fields from the upgrade. If so, delete them and also make sure you remove any related language files and extensions/plugins files left over from the upgrade. Then try accessing the CP again. You might even need to remove the entire module from the database and start over. Hope this helps.
CI Lee's avatar
CI Lee
17 years ago
CI Lee's avatar CI Lee
Hey Mike,
Did you solve this? I was just about to upgrade as well and saw this post.
-Lee
Paul B's avatar
Paul B
17 years ago
Paul B's avatar Paul B
I updated FoxEE to the latest build a minute ago without any issues. Still don’t know how to use the damned module, but that’s another matter.
Mike Young's avatar
Mike Young
17 years ago
The problem was a conflict with having control panel jquery enabled. I disabled it and everything worked ok (except for the control panel jquery of course). Then within a couple hours the devs sent me a couple new versions to try out, the last of which fixed the problem and I can now use CP jquery and have FoxEE working correctly.
Michael Hahn's avatar
Michael Hahn
17 years ago
Michael Hahn's avatar Michael Hahn
I just wanted to chime in here, one to be subscribed to this thread but also to make sure everybody knows that the main place to find FoxEE support is on our EE add-on Forums.
Several people have posted their questions in multiple places (not just you Mike 😉 ) and it is important that we centralize our support. We can provide much more effective response times this way, as well as a place were users can find solid answers.
With that being said, Mike thanks for working with us to get your problem solved and we are still looking into your other post about subscription management.
When upgrading to the most current FoxEE build, if you experience problems you can disable and enable the FoxEE EXTENSION, not the module you will loose your database/product information.
