Hi there,
awesome filter! I’ve had great success with it developing on my local server and now that it’s live it won’t work.
It works when I remove the filter. The thread that led to the discovery that it’s the filter causing it is here: http://ellislab.com/forums/viewthread/99392/#502210
my path and url of my main upload directory is: /home/lamdeni1/public_html/images/uploads/ http://server1.alefhost.com/~lamdeni1/images/uploads/
This is how I’m calling it in my template:
<li><a href="#"><em></em>{exp:imgsizer:size {carousel_photo_1} height="282" width="390" alt="{title}" debug="1"} </li>I’ve tried debug=”1” to see which error I receive and it is:
src = /~lamdeni1/images/uploads/cache/20080916_3390-390x282.JPG img_base = /~lamdeni1/images/uploads/cache img_basename = 20080916_3390-390x282.JPG img_extension = JPG img_filename = 20080916_3390-390x282 img_rootstep = /usr/local/apache/htdocs//~lamdeni1/images/uploads/cache img_rootpath = img_fromroot = /20080916_3390-390x282.JPG /20080916_3390-390x282.JPG is not readable
you can see my site at: http://server1.alefhost.com/~lamdeni1/index.php
on the carousel on the top home page the first image is set to debug, the second is as normal and the third state (“pilot trips”) is the image as it appears when I take the filter off.
HOPE to get to the bottom of this ! Thanks!
Hi Jack!
I fixed my problem..it was 2 issues.
one was the step/path and i fixed it- here is the tutorial
that kinda fixed it but some images still called to local…so I had to delete the appropriate “cache” folder via ftp here is the post about that
good luck!
