Two extensions that add columns to Edit screen ... conflict
hotknife's avatar
hotknife
17 years ago
hotknife's avatar hotknife
Hi, newbie to the extension world. I’m using 2 extensions that add columns to the Edit screen. I can only get one of them to work at a time. Where should I be looking in the files to see where the conflict is? Or can you only add a single extra column to the edit screen?
Leevi Graham's avatar
Leevi Graham
17 years ago
What are the extensions?
hotknife's avatar
hotknife
17 years ago
The extensions are “Restrict Entries” and a “Custom Field on Edit Table” extension that someone whipped up in another thread. (Sorry, I don’t have the links handy.)
But … over in this thread, I solved the issue. Using the Simplify Edit Table ext. cleared out enough space for these new columns to get along.
Thanks, though!
