LG TinyMCE Error
Helmi_xisnet's avatar
Helmi_xisnet
17 years ago
Helmi_xisnet's avatar Helmi_xisnet
HI,
I used EE 1.6.6, after I installed latest LG Tiny MCE and would like to enable it, I got the following error :
Notice: unserialize() [function.unserialize]: Error at offset 65522 of 65535 bytes in /home/abcde/public_html/adminpanel/extensions/ext.lg_tinymce.php on line 1098
Notice: unserialize() [function.unserialize]: Error at offset 65522 of 65535 bytes in /home/abcde/public_html/adminpanel/core/core.extensions.php on line 218
Anyone encountered this problem?
evasion's avatar
evasion
17 years ago
evasion's avatar evasion
Maybe you should clean your cache and try again. I’m using both EE 1.6.6 and LG Tiny MCE without any issue.
Another trick would to create an .htaccess file and add this line :
php_flag display_errors off
It won’t resolve the problem, but should remove the notices.
