LG Polls Question: chart cuts off labels...
4flix's avatar
4flix
17 years ago
4flix's avatar 4flix
Notice how the labels are cut off in the attached chart…
how do I fix this?
thanks
4flix's avatar
4flix
17 years ago
I guess I should have originally posted that I did specify a wider image, but the pie takes up the majority of th area.
I’m sure it’s something I’m doing wrong seeing as how this great mod works well other places. 😊
Tyssen's avatar
Tyssen
17 years ago
Tyssen's avatar Tyssen
Are you increasing the depth as well as the width? If you do that, it’ll scale up and so suffer from the same problem.
