CAPTCHA Extension
combinedmedia's avatar
combinedmedia
17 years ago
combinedmedia's avatar combinedmedia
Hi, I installed Extension and works great! I just have a question, if somebody will put wron answer I still get information: You did not submit the word exactly as it appears in the image or if I wont put anything: You must submit the word that appears in the image
Ho can I change this text? Agata
Max Lazar's avatar
Max Lazar
17 years ago
Max Lazar's avatar Max Lazar
I think that you need look in system\language\english\lang.core.php - language line captcha_required and captcha_incorrect
combinedmedia
17 years ago
Yes, Great thank you very much!
