PHP 5?
mweichert's avatar
mweichert
17 years ago
mweichert's avatar mweichert
When using PHP 5 syntax, I get errors. Is EE not PHP5 compliant? Will it be in v2.0?
Thanks, Mike
Ingmar's avatar
17 years ago
Ingmar's avatar Ingmar
Could you be slightly more specific? What have you tried, what error did you get? I am running EE under PHP 5 without any issues. In fact while EE will work with php 4.x as well, some third-party plugins or extensions won’t.
mweichert's avatar
mweichert
17 years ago
When creating a control panel for my module, I was using:
<?php
  class Sphinx_CP
    public $version = "0.1";
I had to change that to:
<?php
  class Sphinx_CP
    var $version = "0.1";
Thanks for your help.
Cheers, Mike
