LG Extension issues
Podgineer's avatar
Podgineer
17 years ago
Podgineer's avatar Podgineer
Levi
Just needing to find out what’s going on with my system. I installed my purchased extensions as well as some of your free ones and now have some issues with them. For example. When trying to login to the core the following appears for the twitter extension.
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or ‘}’ in /home/9189/domains/podcast-tuneup.com/html/ptcore/extensions/ext.lg_twitter.php on line 634
In EE I remove the extension and then can no longer move forward as it then provides and error stating that the extension is missing. I have been successful in replacing the extension and doing a refresh that will randomly allow access to the core. This extension seems to the problematic one in the group
Before I go mucking around in the DB I thought it best to post and get some guidance to the issue. This is very critical to moving forward as my developers cannot access the system to get work done as we’re under a tight deadline - please respond at your earliest convenience.
Michael Harper
Ingmar's avatar
17 years ago
Ingmar's avatar Ingmar
Michael, there’s nothwing wrong with posting here in the forums for assistance, but if you require assistance and/or a reply by Leevi in person, may I suggest to drop him an email instead?
Mark Bowen's avatar
Mark Bowen
17 years ago
As a quick bit of help on this one if you have disabled an extension (any extension) but then when you hit the template that has the extension tag code on it you will still get an error. You would need to take out the extension tag in the template for that template to not have problems again.
Don’t know if that is the case in this instance but have seen this a few times so thought it might be that.
If for instance you have something like :
{exp:twitter}
or whatever the code is then take that code out of your template and it should start working again. Just disabling and / or disabling the extension from the FTP site won’t make the errors disappear because if you still have the extension tag in the template then the system still tries to load that extension.
Hope that might help a bit?
Best wishes,
Mark
Podgineer's avatar
Podgineer
17 years ago
Thanks guys for the response. The issues isn’t with templates or where the developer placed tags as the extension was just installed and not used in any form as of yet. From the fact that it is installed and running it is now causing an error in the db and simply removing it will not change the issue. I should be able to remove it from the FTP as it has not been implemented in any way. Thus, the question is how to deal with this in the future once I clean the db of the error and move on. Maybe I won’t use the extension. I’ll check with Levi.
BTW - Levi states on his Web site to address issues with any of the extensions in the EE forums. However, I think I’ll send him a note!
Leevi Graham's avatar
Leevi Graham
17 years ago
Hey Michael,
Which version of LG Twitter, PHP & EE are you using?
Cheers
Podgineer's avatar
Podgineer
17 years ago
Hello Leevi!
Well, I have the latest Twitter extension (1.0.2) running on EE 1.6.3. and have PHP 4.4.8 running on A Media Temple Grid-Server. Maybe the PHP is the issue? Thought I checked the specs - I’ll check the CURL support on the service.
Leevi Graham
17 years ago
Hmmm could be an issue with the PHP version although I doubt it… I just uploaded what I have on my dev machine (runs fine) to my site. So grab the latest and see how you go.
The error relates to the end of the extension class… Maybe its because there is two class declarations in the same file?
Could someone with PHP5 install the extension and see if they get the same error?
Podgineer's avatar
Podgineer
17 years ago
Thanks Leevi for the quick response. Of course, you’re coming at me tomorrow I believe - Australia - correct?
I’ll have my Web admin have a thorough look at the issue and see what he can find. I’ll drop another post tomorrow late evening with what we’ve found. Thanks again -
Leevi Graham
17 years ago
In house dev team! What do you need me for 😉
Of course any feedback would be apreciated. 😊
openmotive's avatar
openmotive
17 years ago
openmotive's avatar openmotive
Levi,
We are using the LG TinyMCE extension. It works fine on one server. But a duplicate of that server (files and database) it doesn’t appear to be loading. The symptoms are:
  • When viewing all custom fields for a field group, “WYSIWYG” is not listed on the fields that have been assigned that type (we’ve verified by editing the field itself that it is assigned correctly)
  • When editing a page, the TinyMCE editor does not load. When viewing the source, it does not appear to be being called at all.
We’ve tried removing and reinstalling the extension, as well as removing and reinstalling tinymce to no avail. Any idear what’s going on?
jeff_openmotive's avatar
jeff_openmotive
17 years ago
jeff_openmotive's avatar jeff_openmotive
Hey, Openmotive.
I walked my happy hacking self all the way through leevi’s plugin. At the very end, there is a variable called $out which seems to hold all of the script sources required to call in tinyMCE. If I ‘echo’ that out, tinyMCE comes back! WOOHOO, sort of.
The problem now is that I’m not sure where it is returning that value. My guess is that it is returning the value to core.extensions.php, and that something inside there is eating the value. (Yes that is the technical term).
Perhaps one of the more experienced and or knowledgeable EE pEEple can jump in here and help us understand how core.extensions.php actually works.
Cheers!
silenz's avatar
silenz
17 years ago
silenz's avatar silenz
Has this been resolved somehow?
When I copy the extension into the extension folder and goto Extension Management in order to activate it, I get the error
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /homepages/27/d103776309/htdocs/schreibtisch/extensions/ext.lg_twitter.php on line 635
LG Twitter version 1.0.2 EE 1.6.4 PHP Version 4.4.8 libcurl/7.15.5
silenz's avatar
silenz
17 years ago
Duh, I was blind :red: I’m running PHP 4.
So I had to exchange ‘private’ to ‘var’ here:
/* Username:password format string */
    private $credentials;
    /* Contains the last HTTP status code returned */
    private $http_status;
    /* Contains the last API call */
    private $last_api_call;
and remove ‘private’ here:
private function APICall($api_url, $require_credentials = false, $http_post = false) {
to get me going…
Leevi Graham
17 years ago
Hey Slienz, Thanks for the PHP4 fix I’ll add it to the next release.
Leevi Graham
17 years ago
Levi, We are using the LG TinyMCE extension. It works fine on one server. But a duplicate of that server (files and database) it doesn’t appear to be loading. The symptoms are: * When viewing all custom fields for a field group, “WYSIWYG” is not listed on the fields that have been assigned that type (we’ve verified by editing the field itself that it is assigned correctly) * When editing a page, the TinyMCE editor does not load. When viewing the source, it does not appear to be being called at all. We’ve tried removing and reinstalling the extension, as well as removing and reinstalling tinymce to no avail. Any idear what’s going on? Thanks!
Which version of LG TinyMCE are you using? Also do you have any other extensions installed?
1 2
