CM Strange URL Interpreter [extension]
Gabriel's avatar
Gabriel
17 years ago
Gabriel's avatar Gabriel
CM Strange URL Interpreter extension
This extension gives ability to convert foreign-language characters in entry’s URL Title to proper characters.
Note: This thread is dedicated CM Strange URL Interpreter started in the URL Title Foreign Character Conversion thread.
Installation:
  1. Make sure, you are running ExpressionEngine v.1.6 or above;
  2. Upload the file named “ext.cm_strange_url_interpreter.php” to the folder: /system/extensions/;
  3. Upload the file named “lang.cm_strange_url_interpreter.php” to the proper language folder /system/language/ folder;
  4. Go into the Extensions Manager in your admin area and enable it;
  5. Now will be foreign characters in entry’s title converted to URL title in friendly format. E.g.: “ß” like “ss”; “ш” like “sh” etc.
  6. If you need, modify lang.cm_strange_url_interpreter.php for your native language as you wish.
  7. Enjoy the new EE feature.
Download caleydon.com/en/project/cm-strange-url-interpreter/
History
Version 2.2.0 - 31/08/2008 - Added: Czech language file (Translated by Pavel Kotrla).
Version 2.1.0 - 27/07/2008 - Added: Characters supporting Greek language (Requested by E.ZISI)
Version 2.0.1 - 25/06/2008 - Fixed: Docs. URL
Version 2.0.0 - 14/06/2008 - Changing extension name (Strange URL Interpreter –> CM Strange URL Interpreter); - Rewriting source code; - Added language file contains character array. This allowed modify characters for each other languages.
Version 1.4.0 - 10/11/2007 - Added characters better supporting Hungarian language (Thanks to Istvan Gyorgi).
Version 1.3.0 - 22/09/2007 - Added character set supporting Poland language (Thanks to Gabriel Borkowski).
Version 1.2.0 - 07/07/2007 - Added: Lira, Degree, Yen, Pound and Cent sign; - Fixed: Update and Disable function.
Version 1.1.0 - 25/06/2007 - Renaming of the extension from “Foreign URL Title” to “Strange URL Interpreter”.
Version 1.0.0 - 25/06/2007 - Initial release.
Laisvunas's avatar
Laisvunas
16 years ago
Laisvunas's avatar Laisvunas
Hi Gabriel,
I compiled list of rules enabling to convert the characters from unicode’s greek extended subrange into betacode notation (widely used by classics scholars). These rules are not consistent with current set of rules for converting greek characters and can be used as an alternative for that set.
If you like such contribution, you can freely include it in extension’s package.
Laisvunas's avatar
Laisvunas
16 years ago
FYI: I published a new extension - URL Title Chars, which also converts non-latin characters in URL title, but to specify a conversion rule the user should edit only language file.
Georgiy Ivankin's avatar
Georgiy Ivankin
16 years ago
Georgiy Ivankin's avatar Georgiy Ivankin
Thanks a lot for this! Just want to mention for russian users — cesky language file works fine for russian langauge (with one minor exception — “ц” is transliterated as “c”, not “ts”).
Aenarion's avatar
Aenarion
16 years ago
Aenarion's avatar Aenarion
Any chance we will see this ported to EE 2.0?
In 1.6.8 I had to do a hack in publish file to achieve this before I discover this add-on. It’s very useful for languages other than english.
cheers
vladyn's avatar
vladyn
16 years ago
vladyn's avatar vladyn
absolutely awesome - many thanks !!!
Ramya108's avatar
Ramya108
16 years ago
Ramya108's avatar Ramya108
Very nice, thank you. Just need to add đ (needs to be converted to d).
Can’t quite figure out how to do that. Tried to edit the file (ang.cm_strange_url_interpreter.php), with no results.
Help!
Ramya108's avatar
Ramya108
16 years ago
Gabriel, do you still support this extension? I need your help. I am trying to add Croatian characters đ and Đ, but to no avail.
I inserted the following lines of code into the “lang.cm_strange_url_interpreter.php:
‘cm_272’ => “d”, // Đ ‘cm_273’ => “d”, // đ
But that does not seem to work. Please help!
