Duplicate Titles / Unique URL Titles
gridonic's avatar
gridonic
17 years ago
gridonic's avatar gridonic
So with that hook would it instead not just be easier on the system to append the entry_id of the entry you are about to publish to the end of the url_title instead?
In my eyes, this would be the safest way, appending timestamps gives you even uglier URLs anyway and there can’t be two entry_ids with the same value (in one site) i suppose.
Mod Edit: Split from this feature request.
Mark Bowen's avatar
Mark Bowen
17 years ago
Yep that’s what I thought. Now if only I had the first inkling of how to do that 😉
Mark
gridonic's avatar
gridonic
17 years ago
Hey Mark
Shouldn’t be that hard, try to have a look at “submit_next_entry_start” hook, do a print_r of the $_POST var, i suppose the url_title will be theresomewhere, you could dynamically change that value for starters.
Mark Bowen's avatar
Mark Bowen
17 years ago
Will take a look at what you have said there - the print_r I mean. I see that a lot but never totally understand how to use it all and then even when I do see the results from those kinds of things I still don’t know how to go about modifying them on the fly.
Will take a look though. Really don’t think I will get it though.
Best wishes,
Mark
gridonic's avatar
gridonic
17 years ago
Hm, let me see, maybe I will have a look at this one too 😉
gridonic's avatar
gridonic
17 years ago
Ok here it goes: if you use the mentioned hook, you can do a simple print_r (see PHP docs, prints out the content of a variable) to see what and how it is passed through the hook.
Array
    [weblog_id] => 1
    [entry_id] =>
    [entry_date] => 2008-06-05 11:08 AM
    [expiration_date] =>
    [comment_expiration_date] =>
    [author_id] => 1
    [new_weblog] => 1
    [status] => open
    [allow_comments] => y
    [dst_enabled] => y
    [trackback_urls] =>
    [title] => A test entry
    [url_title] => a_test_entry
    [submit] => Submit
    [mode] => normal
    [field_id_1] =>
    [field_ft_1] => xhtml
    [field_id_2] =>
    [field_ft_2] => xhtml
    [field_id_3] =>
    [field_ft_3] => xhtml
This $_POST array contains an entry
which means you could start doing changes (e.g. appending the entry_id) to it. To append the entry id, you’d have to use a later hook as here, the entry_id coming from the post is, of course, still empty.
Just giving you some ideas.
Mark Bowen's avatar
Mark Bowen
17 years ago
Hiya,
Thanks for that. Still not entirely certain what you did there but I will take a look at this myself and see if I can get my head around it. May take a while though as I am still stuck with a plugin that I am trying to creates (no-one seems to like me in the plugins forum :down: ).
Thanks again for the pointers on this though.
Best wishes,
Mark
RobJ25's avatar
RobJ25
17 years ago
RobJ25's avatar RobJ25
Hey Mark,
Did you have any luck with this? I need to do something very similar indeed except add the entry_id to the front of the url_title. I’d be incredibly grateful for any tips you can offer…
Rob
Mark Bowen's avatar
Mark Bowen
17 years ago
My tip would be that I need to get more sleep (hmm actually that’s more a tip for me really! 😉 ).
Unfortunately other work got in the way of me looking at this one so had to take a back-burner. I may when I get the chance take another look into doing this as I do feel that it is something that is really really needed personally.
Sorry that I don’t have any information other than I slacked out on this one 😊
Best wishes,
Mark
RobJ25's avatar
RobJ25
17 years ago
So I finally tried to get my head around extensions and took a run at this.
It seems to work, but since this is my first run, I’d be very grateful for any tips or improvements anyone can offer:
<?php
class entry_id_in_url_title
    var $settings = array();
    var $name = 'Entry_id in url_title';
    var $version = '1.0';
    var $description = 'Inserts entry_id into url_title when submitting new entry';
    var $settings_exist = 'n';
    var $docs_url = '';
    function entry_id_in_url_title($settings='')
        $this->settings = $settings;
    function insert_entry_id($entry_id, $data, $ping_message)
        if (array_key_exists('entry_id', $data)) // only perform if this is a new entry (not an update)
            $new_url_title = $entry_id.'-'.$data['url_title'];
            $_POST['url_title'] = $new_url_title; // in case any other extensions are making use of the $_POST data
            // save to the database
            global $DB, $FNS;
            $update_data = array('url_title' => $new_url_title);
            $sql = $DB->update_string('exp_weblog_titles', $update_data, "entry_id = '{$entry_id}'");
            $DB->query($sql);
            $FNS->clear_caching('all');
    function activate_extension()
        global $DB;
        $DB->query($DB->insert_string('exp_extensions',
                array(
                'extension_id'    => '',
                'class'            => 'entry_id_in_url_title',
                'method'        => 'insert_entry_id',
                'hook'            => 'submit_new_entry_end',
                'settings'        => '',
                'priority'        => 10,
                'version'        => $this->version,
                'enabled'        => 'y'
    function disable_extension()
        global $DB;
        $DB->query("DELETE FROM exp_extensions WHERE class = 'entry_id_in_url_title'");
RobJ25's avatar
RobJ25
17 years ago
I’ve edited the code above to include the clear_caching function at the end. It appears that submit_new_entry_end is called after EE clears the caches upon submitting a new entry. If you use url_titles to link to entries, you risk 404s without this line, since the url_title will have been changed after the caches have been refreshed and pages rebuilt.
Ian Beck's avatar
Ian Beck
16 years ago
Ian Beck's avatar Ian Beck
I’ve added some logic to RobJ25’s original extension that adds the following:
  • You are required to select which weblogs to add entry_ids to url_titles (since I rarely find it desirable to have this functionality on all my weblogs)
  • You can choose to either prepend or append the entry_id
  • The separator between the entry_id and the url_title will be based on your system-wide preference for dashes or underscores
Here’s the files you need to make it work. Make sure to customize the settings once you’ve activated the extension:
ext.entry_id_in_url_title.php
<?php
class Entry_id_in_url_title
    var $version = '1.1';
    var $description = 'Inserts entry_id into url_title when submitting new entry to maintain unique URL titles';
    var $settings_exist = 'y';
    var $docs_url = '';
    function Entry_id_in_url_title($settings='')
        $this->__construct($settings);
    function __construct($settings='')
        global $PREFS, $DB, $FNS;
        if (array_key_exists('entry_id', $data) && array_search($data['weblog_id'], $this->settings['chosen_weblogs']) !== FALSE) // only perform if this is a new entry (not an update) and a managed weblog
            $sep = ($PREFS->ini('word_separator') == 'dash' ? '-' : '_');
            if ($this->settings['position_of_id'] == 'front')
                $new_url_title = $entry_id.$sep.$data['url_title'];
            else
                $new_url_title = $data['url_title'].$sep.$entry_id;
            $sql = $DB->update_string('exp_weblog_titles', $update_data, "entry_id = '".$entry_id."'");
            $DB->query($sql);
    function settings()
        global $DB;
        $query = $DB->query("SELECT weblog_id, blog_title FROM exp_weblogs ORDER BY blog_title ASC");
        $weblogs = array();
        if ($query->num_rows > 0)
            foreach($query->result as $row)
                $weblogs[$row['weblog_id']] = $row['blog_title'];
        $settings['chosen_weblogs'] = array(
            'ms',
            $weblogs,
        $settings['position_of_id'] = array(
            'r',
            array(
                'front' => 'prepend',
                'back' => 'append'
            'back'
        return $settings;
        global $DB;
                array(
                'settings'        => '',
                'priority'        => 10,
                'enabled'        => 'y'
        global $DB;
lang.entry_id_in_url_title.php
<?php
$L = array(
// Required for settings
'chosen_weblogs' => 'Choose weblogs to have entry_ids added to url titles',
'position_of_id' => 'Choose location of entry_id',
'prepend' => 'Prepend to url_title (ex: "123-my-entry-title")',
'append' => 'Append to url_title (ex: "my-entry-title-123")',
// END
