URL Field Extension
gridonic's avatar
gridonic
17 years ago
gridonic's avatar gridonic
Hi
Just finished creating my first extension based on this thread.
The latest version including a short documentation can be found here:
URL Field Extension for Expressionengine
I really love EE, don’t get me wrong, but one thing i have to rant about is the missing API for developers. Hooks and all are nice, but if you have use preg_replace so many parts of HTML code to build-in your functionality the happyness stops. I just hope EE 2.0 will correct this and provide a better API for developers.
Mark Bowen's avatar
Mark Bowen
17 years ago
Peter,
Let me be the first to say a very big well done on this one. A fantastic little extension that does exactly what it says on the tin and then some!! 😉
Brilliant addition to ExpressionEngine. Thanks again!
Best wishes,
Mark
Versa Studio's avatar
Versa Studio
17 years ago
Versa Studio's avatar Versa Studio
Peter,
Great work. I just posted a request for this last week, and here it is! Bravo.
Ben
Danny T.'s avatar
Danny T.
17 years ago
Danny T.'s avatar Danny T.
This might be totally missing the point of your extension, but would it be possible to add an option to remove the formatting that is produced through this field type? I wanted to do something like this:
<a href="http://{url_field}">Source</a>
I know this can be done with a standard text field, but I think the validation check is a good idea. I’ll be having some more novice computer users updating the site, so it would be great if the validation check can give them a sense of pattern for publishing.
Cheers!
gridonic's avatar
gridonic
17 years ago
Hi
I’m not aware of any formatting issues? You can chose the url_field (as any other field type) not to have any formatting.
If I type “http://www.example.com” in the url_field, the url is returned exactly as is.
Danny T.'s avatar
Danny T.
17 years ago
That’s odd.. I’m not getting the same results. When I try and edit the formatting for the URL Field, it basically says that “Text formatting is not available for your chosen field type”.
When I plug in {source} into a template, which is the name of my URL field, I get this outputted:
<a href="http://hypebeast.com/2008/06/nike-blazer-lax-los-angeles-exclusive/">http://hypebeast.com/2008/06/nike-blazer-lax-los-angeles-exclusive/</a>
Seems formatting is done automatically, so I can’t specify a name for the link. Ideas are appreciated.
Mark Bowen's avatar
Mark Bowen
17 years ago
Try going to :
Admin->Weblog Administration->Weblog Management->Edit Preferences (Your Weblog Name)->Weblog Posting Preferences->
You should see an option that says :
Automatically turn URLs and email addresses into links?
Change that to No and see if that fixes it?
Best wishes,
Mark
gridonic's avatar
gridonic
17 years ago
Thanks Mark, faster as usual 😛
That should chang the behaviour indeed mr_dimsum, please report back if not.
james Brown's avatar
james Brown
17 years ago
james Brown's avatar james Brown
one question/bug/feature request… it seems that it only validates the field when you click the little icon. I was assuming that it would check it on a submission. I can’t assume that my users will actually remember to push the link button every time. I want to be sure they have a correctly formed url even if they don’t remember to push the icon button.
Also, I noticed that it doesn’t see https:// as a valid url link.
gridonic's avatar
gridonic
17 years ago
Hi
Thanks for getting back to us, we’re aware of the fact that this functionality is not included in the current release, but we’ll incorporate it for the next one.
Currently, we’ve our hands pretty full with client work, as soon as it gets better, we’re release a new version along with an entire new extension (something cool for freeform 😉.
Regards Peter.
james Brown
17 years ago
can’t wait for the new updates! right now i can’t really use the extension, because I need the https:// support.
gridonic's avatar
gridonic
17 years ago
Hi James
You can update to the latest version which fixed the https:// issue as well as the formatting issue, read the comments on our blog on how to fix the formatting.
We also have plans to add CURL checking of URLs so that upon entry submission, the extension would check using CURL is the header response returned from the URL is valid and thus the url itself. This should be more effective than using just a regular expression. Hopefully we’ll be able to release another update addressing this issue.
Matt Weinberg's avatar
Matt Weinberg
17 years ago
Matt Weinberg's avatar Matt Weinberg
Hi Peschehimself– thanks for all your work on this. Would it be possible to make curl checking optional (a settings checkbox or something…)?
Thanks, Matt
gridonic's avatar
gridonic
17 years ago
Hi Matt
Yes, of course, the CURL will a have a separate settings value, but it will most probably be a global settings instead of a per weblog setting.
Benjamin David's avatar
Benjamin David
about 16 years ago
Benjamin David's avatar Benjamin David
Try going to : Admin->Weblog Administration->Weblog Management->Edit Preferences (Your Weblog Name)->Weblog Posting Preferences-> You should see an option that says : Automatically turn URLs and email addresses into links? Change that to No and see if that fixes it? Best wishes, Mark
Do you know some way we could enable/disable the “Automatically turn URLs and email addresses into Links ? To no” on the fly from a plugin file ? Looks like impossible as if the option is set to “Yes” it seems to break the template parsing when passing a channel/weblog variable into a plugin parameter. But I would be very interested in finding such a fix for the Video Player plugin. Plugins like ImgSizer, CSVGrab also seem to have such issues with URL parameters.
