I can’t seem to get the XML Encode plugin (1.2) to work (on EE 1.6.3). If I understand correctly, it should take something like this:
{exp:xml_encode}http://test.com?a=1&b=2&c=3{/exp:xml_encode}…and output
http://test.com?a=1&b=2&c=3…(ampersands converted to the XML entity &). However, my output is the original unencoded string:
http://test.com?a=1&b=2&c=3Oddly, if I try:
{exp:xml_encode protect_entities="yes"}http://test.com?id=1&p=&z=26{/exp:xml_encode}…then the encoded & entities get unencoded, resulting in:
http://test.com?a=1&b=2&c=3What am I doing wrong?
