Magpie Output with extra <br />
lincolnpixel's avatar
lincolnpixel
18 years ago
lincolnpixel's avatar lincolnpixel
Hi, i’m trying to display some photogallery thumbnails from a pixelpost photogallery on my site using the Magpie plugin, it seem that everything is working, the problem i’m having is the extra line break tag on the output, like this
<li><a href="http://frankydj.com/photoblog/index.php?showimage=146">_        <img src="http://frankydj.com/photoblog/thumbnails/thumb_20080427163906121_DSC_2994.jpg" alt=""  /><br>_    </a></li>
{exp:weblog:entries weblog="gallery_xml"}
<h1>{title}</h1>
{exp:magpie url="{feed}" limit="10" refresh="720"}
<ul>
{magpie:items}
<li><a href="http://{magpie:link}">{magpie:description}</a></li>
{/magpie:items}
</ul>
{/exp:magpie}
{/exp:weblog:entries}
How can i remove the tag? Thanks
Bruce2005's avatar
Bruce2005
18 years ago
Bruce2005's avatar Bruce2005
Edited.
Look at the feed, it must be in the description in the rss. Viewing the feed:
<description>
        <img src="http://frankydj.com/photoblog/thumbnails/thumb_20080427163911125_DSC_2886.jpg
"><br/>
    </description>
If you cannot edit the feed, or use backspace? the enclosure url element has a clean url, I use the regular magpie so not sure if the plugin does enclosures? Or use php:
<?php
$string = "Free stuff
$newstring = substr($string, 0, -6);
echo $newstring;
Removes the tag, the one on the image isn’t right as it should have a space…
lincolnpixel
about 18 years ago
Bruce, thanks, i cant edit directly the feed, where should i use the php code?
Bruce2005's avatar
Bruce2005
about 18 years ago
The description in there, but is not be best idea, I usually go like:
{magpie:items}
<?php
$desc = '{magpie:description}';
$string = "$desc";
<li><a href="http://{magpie:link}"><?php echo "newstring"; ?></a></li>
This is rough and will cause problems when: There is no break tag. There is a space as there should be. Does magpie plugin do enclosures? That one is without tags…
The extract url plugin may be best bet here..gives you a clean url and you can add the img tag to the template code. .
lincolnpixel
about 18 years ago
Bruce, Thanks a lot for sharing your time, the problem was not the Magpie plugin but the pixelpost photogallery output code, adding the extra <line breaks> tags. Resolved.
