Trimmer plugin breaks magpie
EliVZ's avatar
EliVZ
18 years ago
EliVZ's avatar EliVZ
Maybe I am missing something, but using the Trimmer plugin inside my Magpie block breaks Magpie. My code is:
{exp:trimmer left="3" right="4"}{description}{/exp:trimmer}
I am trying to cut the paragraph tags off the ends of the description, but instead I get “script”, which threw me of for a while, until I realized that “script” is “{description}” with the first 3 and the last 4 characters cut off.
So how do I get EE to process the Magpie tag before the Trimmer tag? Am I doing something really stupid here? Thanks.
jensa's avatar
jensa
18 years ago
jensa's avatar jensa
@EliVZ Check out this page http://expressionengine.com/docs/templates/plugins.html and look for: parse=”inward”. You can find an example with Magpie here:
http://ellislab.com/forums/viewthread/72070/
J
EliVZ's avatar
EliVZ
18 years ago
Thanks, Jensa, that did the trick.
-Eli
