Looking for "on entry update" hook
Brandon Kelly's avatar
Brandon Kelly
18 years ago
Brandon Kelly's avatar Brandon Kelly
Hi all,
I need to write an extension that sends a notification e-mail out when an entry gets updated, but I can’t seem to find a hook that gets called when the publish form is submitted.
Am I just blind or what?
silenz's avatar
silenz
18 years ago
silenz's avatar silenz
There is no separate update function.
New entries as well as updates are both handled by the function submit_new_entry() in cp.publish.php and the hook you are looking for will probably be “submit_new_entry_start” or “submit_new_entry_end”.
Whether it is an update you are dealing with you’ll have to figure out yourself.
Brandon Kelly
18 years ago
I was under the impression that that only got called on new entries. (Somewhat misleading name.)
I have no problem figuring out if it’s a new entry or not.
silenz's avatar
silenz
18 years ago
If it is a new entry the $data-array contains the key-/value-pair ‘entry_id’ => ”. If it is an update that key is missing.
So if you take the ‘submit_new_entry_end’ hook something like this should point you into the right direction:
if ( array_key_exists("entry_id", $data) )
  //It's a new entry
else
  //It's an update
Brendon Carr's avatar
Brendon Carr
18 years ago
Brendon Carr's avatar Brendon Carr
There really ought to be a hook for notifications upon update.
We’re working on a law firm site (for my law firm), and would like to have the ability to allow site visitors to request a notification if a certain article changes.
Brandon Kelly
18 years ago
“submit_new_entry_end” should do the trick, as silenz has pointed out.
Brandon Kelly
18 years ago
I finally got around to releasing this extension today:
http://ellislab.com/forums/viewthread/76075/
Thanks for your help, silenz!
DEA's avatar
DEA
about 17 years ago
DEA's avatar DEA
Hmm, this is an ancient thread but I have a question. If the entry_id key is not present in an update, how do we know which records to update in the db? I’m sure it’s a stupid question, but I don’t get it… 😕
silenz's avatar
silenz
about 17 years ago
$edata = $EXT->call_extension('submit_new_entry_end', $entry_id, $data, $ping_message);
Well, the entry_id is in the 2nd argument ($entry_id) in both cases.
