Slow performance with file, checkbox, and multi-relationship extensions
ebcms's avatar
ebcms
18 years ago
ebcms's avatar ebcms
Does anyone have suggestions for improving performance when using these extensions.
I’ve followed the optimizing and other performance tips (use of disable=, caching, etc.) but we’re still seeing a huge hit from these extensions.
From the debugging, it appears that each weblog entry generates three separate calls - one for each extension.
<snip> (1.563343) Calling Extension Class/Method: Checkbox/modify_template (1.566470) Calling Extension Class/Method: Mh_file_ext/modify_template (1.572031) Calling Extension Class/Method: Multi_relationship/modify_template (2.671512) Calling Extension Class/Method: Checkbox/modify_template (2.674874) Calling Extension Class/Method: Mh_file_ext/modify_template (2.680559) Calling Extension Class/Method: Multi_relationship/modify_template (4.580739) Calling Extension Class/Method: Checkbox/modify_template (4.584072) Calling Extension Class/Method: Mh_file_ext/modify_template (4.589789) Calling Extension Class/Method: Multi_relationship/modify_template </snip>
As we are calling in a related weblog to display nearly 100 entries, it’s causing a horrible situation. Caching helps upon return to the page, but the initial load is really bad.
The dev box this is on is admittedly old and slow so I expect performance will be better in production, but even so, this seems very inefficient.
Any suggestions?
ian Pitts's avatar
ian Pitts
16 years ago
ian Pitts's avatar ian Pitts
I’m having an identical situation on a site due to launch on the 5th and we’re pulling our hair out trying to figure this out…
