Bad Behavior 2 Ext. = Blank Site :-(
PXLated's avatar
PXLated
18 years ago
PXLated's avatar PXLated
Had a customer site getting bombarded with comment spam so installed the Comment Spam Prevention (v1.1) and Bad Behavior 2 extensions. If the BB2 extension is enabled, I get a blank screen when the site is loaded (all URL variations). Didn’t see anything mentioned other than install the files and enable within the CP. Is there something else that’s needed/required?
Andru Edwards's avatar
Andru Edwards
17 years ago
Andru Edwards's avatar Andru Edwards
What was the solution here? Did you get it figured out?
PXLated's avatar
PXLated
17 years ago
No I didn’t, gave up as there wasn’t much spam at the site I was dealing with.
gridonic's avatar
gridonic
17 years ago
gridonic's avatar gridonic
Try the akismet extension, it’s doing a great job in preventing spam.
Andru Edwards
17 years ago
It’s good, but certainly not enough on its own. I use both, but on occasion, I get this same blank screen problem with Bad Behavior 2.
