(MH) File Extension - Max Size Issue (php.ini)
Simon Scheiber's avatar
Simon Scheiber
18 years ago
Simon Scheiber's avatar Simon Scheiber
Hi there,
I’m getting the following error when uploading a large file ‘the file size of name.flv is larger than what is allowed in your php.ini.’ Thus I changed the following values in the php.ini file to be higher than the size of the file I tried to upload; post_max_size = 25M and max_file_size = 25M. But somehow it seems that this doesn’t fix the problem! Can someone help me with that (probably teeny tiny) issue? Thanks in advance!
Update: Geez, found the solution; forgot to set the upload_max_filesize value…
