Latest 1st party module versions?
Leevi Graham's avatar
Leevi Graham
18 years ago
Hey guys,
I think this one is for the dev team but if you know the answer feel free to chime in…
Is there a way to access the version number and build of the first party modules?
The reason I ask is I would like to expand the capabilities of my: LG Latest EE plugin.
Maybe there could be a text file (similar to eeversion.txt) that can be parsed by: http://au2.php.net/parse_ini_file?
I realise you guys have your hands full at the moment so its not a major issue. Maybe something like this can be added for the 2.0 release?
Cheers
ExpressionEngineer's avatar
ExpressionEngineer
18 years ago
ExpressionEngineer's avatar ExpressionEngineer
You can access the version number in the exp_modules table, or you can fetch the $version from the cp. files of each module.
Just some thoughts..
Leevi Graham
18 years ago
I was actually referring to the latest download available on the EE site
ExpressionEngineer
18 years ago
You kinda neglected to mention that in your first post. 😊
Leevi Graham
18 years ago
Yeah you’re right 😊 I should have been clearer
