Repeet plug-in not repeating properly
Clearpeak's avatar
Clearpeak
18 years ago
Clearpeak's avatar Clearpeak
I have been using the repeet plug-in and I just realized it doesn’t repeet properly.
I set a event entry date and expiration date 3 mos later and set the repeet interval to daily and it repeets properly for the first month but then it won’t repeet for the next two months. I can’t figure out what in my code is wrong. I’m using version 1.6. Here is my template. Thanks
{exp:repeet:parse date_header_interval="day"}
  {repeet:date_header}<h3>%l %j</h3>{/repeet:date_header}
  {repeet:no_results}<h3>Sorry, there are no events scheduled for this date.</h3>
{/repeet:no_results}
  {exp:repeet:get_ids weblog="calendar" parse="inward" status="not Test|closed" }
    {exp:weblog:entries weblog="calendar" entry_id="{repeet:entry_ids}" dynamic="off" show_expired="yes" show_future_entries="yes" status="not Test|closed"}
    {repeet:item}
      {repeet:entry_date}{entry_date format="%Y-%m-%d %H:%i"}{/repeet:entry_date}
      {repeet:expiration_date}{expiration_date format="%Y-%m-%d %H:%i"}{/repeet:expiration_date}
      {repeet:interval}{repeat_interval}{/repeet:interval}
      {repeet:include_dates}{include_dates}{/repeet:include_dates}
      {repeet:exclude_dates}{exclude_dates}{/repeet:exclude_dates}
      {repeet:display}
<div id=”entry”> Read More »
• Tell a friend about this event </div> {/repeet:display}
    {/repeet:item}
    {/exp:weblog:entries}
  {/exp:repeet:get_ids}
{/exp:repeet:parse}
Clearpeak's avatar
Clearpeak
18 years ago
Anyone heard from Mr. Wilson lately?
rockthenroll's avatar
rockthenroll
18 years ago
rockthenroll's avatar rockthenroll
You still having this issue? I know this is long after, but just saw this. DM me if you still need help I might be able to lend a hand.
