LG TinyMCE: My images disappear
pmatos's avatar
pmatos
18 years ago
pmatos's avatar pmatos
I decided to go for LG TinyMCE, great extension, however I’m having a problem. I had already done most of my website content, and added images using the “Upload File” feature on EE. When I edit an article, now that it has the LG TinyMCE enabled. My images disappear.
Links are supposed to work like this: https://ellislab.com/asset/images/ent-partner-logo/imagename.jpg
When I check the HTML, it gets changed to this and the image no longer works: /https://ellislab.com/asset/images/ent-partner-logo/imagename.jpg
pmatos's avatar
pmatos
18 years ago
Ok, I just noticed if I try to use the “Upload File” option on the LG TinyMCE fields, It doesn’t add the url of the file uploaded. So “Upload File” will become useless to my client as he wont be able to embed images or other files.
What is the easiest way for users to add/edit their own images with TinyMCE?
pmatos's avatar
pmatos
18 years ago
or in your TinyMCE settings set relative URLs to Yes (which is a bad idea 😛)
Why is it a bad idea?
