TinyMCE vs LG TinyMCE
pmatos's avatar
pmatos
18 years ago
pmatos's avatar pmatos
While searching on the Add-On page, I see Paul Burdick’s TinyMCE extension and Leevi Graham’s LG TinyMCE Custom Field extension.
Whats the diference between them? Which one is better and why?
tedfitzpatrick's avatar
tedfitzpatrick
18 years ago
tedfitzpatrick's avatar tedfitzpatrick
Hey pmatos,
I’m installing these right now, too. It’s my understanding that both extensions are required for the WYSIWG editor to work. I haven’t been able to make it work yet, so I’m reading through the forums!
Ted
tedfitzpatrick
18 years ago
hey pmatos,
TinyMCE makes ALL text fields WYSIWG. Adding LG TinyMCE allows you to specify only certain text fields within your publish/entry form to be WYSIWG.
I just got it working! Way cool. Now to figure out the best workflow for people uploading files and creating links …
Ted
Leevi Graham's avatar
Leevi Graham
18 years ago
Hey Ted,
My extension also allows you to use the TinyMCE Gzip compressor for even faster speeds.
Cheers
Leevi Graham
18 years ago
