LG TinyMCE not showing up in Field Formatting Options
kirkaracha's avatar
kirkaracha
18 years ago
kirkaracha's avatar kirkaracha
I installed LG TinyMCE according to the directions (I also installed TinyMCE Compressor). The scripts’ permissions are 755. I enabled the extension, and I have the correct paths to the JavaScripts in the extension (verified by loading the script in a browser and copying the full URL). I’m running 1.6.2.
LG TinyMCE isn’t listed as an option under Field Formatting Options. Did I miss something?
Leevi Graham's avatar
Leevi Graham
18 years ago
In the drop down its listed as WYSIWYG. Is that there?
kirkaracha's avatar
kirkaracha
18 years ago
No, WYSIWYG isn’t listed. (I didn’t look for that the first time because the instructions say “choose LG TinyMCE as the field type.”)
kirkaracha's avatar
kirkaracha
18 years ago
My mistake. I was looking at Default Text Formatting for This Field instead of Field Type.
Leevi Graham
18 years ago
No worries, I just posted a new version of the extension you will probably want to download… Check it out at my ExpressionEngine extensions site.
Any chance of getting the subject of this topic prefixed with “SOLVED:”? 😊
Leevi Graham
18 years ago
There is an issue regarding number of rows for the editor. This will be fixed in the next version…
If you want the jump change line 545 of the extension to:
"textarea_block" => "block",
Cheers Leevi
