How difficult to write an extension that writes to two weblogs in the Control Panel->Publish page ?
RipeMedia's avatar
RipeMedia
18 years ago
RipeMedia's avatar RipeMedia
I want to create two weblogs at once in the Control Panel->Publish page, the 2nd being a related weblog entry that can either be selected if it already exists (as you can presently do), or be inserted then & there, so the admin isn’t forced to Publish two different weblog entries separately ?
[Mod edit: moved to Extension Discussion forum]
RipeMedia's avatar
RipeMedia
18 years ago
Just so there’s no confusion, the first part of that statement should read:
I want to create two weblog entries at one time in the Control Panel->Publish page
stinhambo's avatar
stinhambo
18 years ago
stinhambo's avatar stinhambo
What is your reasoning for doing this?
RipeMedia's avatar
RipeMedia
18 years ago
Requirements. The client wants to be able to enter one weblog entry per member instead of two, and it’s appropriate for the data in both to be separated because the base data used in other weblogs. Data A Data B
Data A is base data for a member. Data B is information specific to both Data A and Data B being displayed.
Two other weblogs utilize Data A as base data for their specific use.
Make sense ?
Jamie Poitra's avatar
Jamie Poitra
18 years ago
Jamie Poitra's avatar Jamie Poitra
RipeMedia,
Shouldn’t be too bad.
Using the submit_new_entry_end hook you can grab all of the data that was submitted and then use it to create a second entry wherever you want. You can likewise go back and make changes to the original afterwards (like for instance if you wanted to select the new entry dynamically generated in a field in the original).
Jamie
