Hout's checkboxes and weblog:entries search tag
oldgoldblack's avatar
oldgoldblack
18 years ago
oldgoldblack's avatar oldgoldblack
I’m tyring to limit entries displayed on a page by searching a custom field with the new search:field_name= parameter. The field I’m searching uses Mark Hout’s checkboxes extension.
So far, no good. It returns every available entry and does not limit at all.
Docs say:
NOTE: Only custom fields of the type “Text Input”, “Textarea”, and “Drop-down Lists” are searched with this parameter.
Yet Checkboxes is “like” drop-down lists.
Does this function play nice with the extension? Would it play nice with Hout’s custom field limiter extension?
Or did I maybe just screw up the function call?
oldgoldblack
18 years ago
Okay, the problem appears to be that I was using the search:field_name= in a reverse_related_entries tag, which obviously does not work. Which means I’m totally screwed.
The search parameter scans the custom field fine in a typical weblog tag.
So, nevermind.
allgood2's avatar
allgood2
18 years ago
allgood2's avatar allgood2
Hey oldgoldblack, did this actually work with the extension, or did you give up because of the related entries tag?
oldgoldblack
18 years ago
It’s been a few days, but if I remember correctly, both the extension and the search function actually worked fine outside related entries tag in my testing. Though I did not thoroughly flesh that out.
