LG Better Meta 1.4.0 - NEW RELEASE!
Leevi Graham's avatar
Leevi Graham
18 years ago
Hey guys,
Just a quick message to say I have released v1.4.0 of LG Better Meta.
Change Log:
  • Extension method names changed Update will handle this although there will be a one off error. Just refresh the page and you will be OK
  • Encoding characters bug fixed
  • Editing from pages module bug fixed
  • Source Code fully commented in PHPDoc syntax
There is also a commercial version available that removes the attribution. Until I setup a payment system drop me a PM if your interested in purchasing.
Grab it from the documentation page.
Cheers
Nekrawulf's avatar
Nekrawulf
18 years ago
Nekrawulf's avatar Nekrawulf
I installed it.
DO I have to make any changes to the Meta fields of each template, or does this extension automatically overide meta description/keywords that are present in the parent weblog template?
This is all brand new to me so please bear with me.
Leevi Graham
18 years ago
LG Better Meta allows you to create default meta using the extension settings. You then have the option to add custom values in the Better Meta tab.
If you add values in the tab they will be used, else the default values will be used.
Nekrawulf's avatar
Nekrawulf
18 years ago
Wrong forum… taken to PM
Matt Johnson's avatar
Matt Johnson
18 years ago
Matt Johnson's avatar Matt Johnson
Hey Leevi,
I installed this extension and it worked great for a few days…and then we didn’t touch it since and now we want to edit some meta data or add new articles and when we click on the “Better Meta” tab nothing shows up.
I downloaded a fresh install of the extension and then re-uploaded it and that didn’t seem to fix it. I also never touched any parts of the back-end of EE or of the extension.
Any suggestions?
Matt Johnson
18 years ago
And when I say, “Not showing up” I mean,
When we click the tab “Better Meta” its supposed to show us the fields - but it doesn’t change the screen at all.
Infact, the entire “tabs” bar disappears.
Leevi Graham
18 years ago
And when I say, “Not showing up” I mean, When we click the tab “Better Meta” its supposed to show us the fields - but it doesn’t change the screen at all. Infact, the entire “tabs” bar disappears.
Hey Mat,
Which other extensions do you have installed?
Matt Johnson
18 years ago
Tag Submit (v.2.0.7) Edit Tab AJAX (v.1.2.1) Sitemap Pinger (v.1.1) Add Sitename (v.1.1.4) LG Better Meta (v.1.4.0)
I found which one was causing the problem: Sitemap Pinger (v.1.1)
When I disabled it, Better Meta worked fine.
Leevi Graham
18 years ago
Yeah I have buzzed the developer and left a comment on his blog… Yet there has been no fixed released. I suggest you comment on his blog as well and add a little more pressure 😊
Matt Johnson
18 years ago
Oh okay, thanks again Leevi!
the_crimsonrooster's avatar
the_crimsonrooster
18 years ago
the_crimsonrooster's avatar the_crimsonrooster
Leevi,
It appears LG Better Meta and Restricted entries don’t play well together. When I enable Better Meta and create or edit an entry - the groups tab (restricted entries) doesn’t function properly. If you click the Groups tab, it disappears. You have to refresh the page it comes back. If I disable the LG Better meta tool, restricted entries works again.
Leevi Graham
18 years ago
Leevi, It appears LG Better Meta and Restricted entries don’t play well together. When I enable Better Meta and create or edit an entry - the groups tab (restricted entries) doesn’t function properly. If you click the Groups tab, it disappears. You have to refresh the page it comes back. If I disable the LG Better meta tool, restricted entries works again.
Hey the Rooster,
Can you send me the url of the “Restricted Module”? I’m guessing the developer is not checking to see if anyone else is using the same extension.
Cheers
the_crimsonrooster
18 years ago
http://www.purple-dogfish.co.uk/free-stuff/restrict-entries
Leevi Graham
18 years ago
Hey hey….
Ok this one was my fault :(
Heres the quick fix….
Line 508 should be:
$ret .= "<!-- Start LG Better Meta Tab -->";
Notice the . (period) I’ll prepare a new version and try and get it up today.
Thanks for spotting this one!
Full apologies for assuming 😊
Leevi Graham
18 years ago
This has now been fixed… Grab 1.4.2 from the LG Better Meta documentation page.
1 2 3 Last
