SAEF - output from plugin changes inside {exp:weblog:entry_form}
nanook's avatar
nanook
18 years ago
nanook's avatar nanook
Hi all,
I have someone else doing all the “standard” templating stuff, which leaves me with the funky bits.
Right now, I’m working on a multilingual SAEF. Language info is coming from a PHP session, which I initiate via a plugin: my_session. This works just fine.
However, inside the {exp:weblog:entry_form}, my plugin output is different from outside.
An example:
{exp:my_session:get_language_output}
{exp:weblog:entry_form weblog="my_weblog" return="site/index"}
{/exp:weblog:entry_form}
The output:
English M00o93H7pQ09L8X1t49cHY01Z5j4TT91fGfr
“English” is the correct output, of course. I’ve read the appropriate section of the user guide and searched the forums, but couldn’t find any reference.
Any clues? Assigning it to a variable and using that doesn’t work either.
TIA… Nico
18 years ago
It kind of looks like a placeholder, but I’m not sure why. If you hard code it, it comes out fine- correct? What’s the plugin doing?
nanook's avatar
nanook
18 years ago
Hi Robin,
The plugin just return()’s a string, in this case the string “English”. If I declare a variable like
{assign_variable:mylang="English"}
and use
{mylang}
outside and inside, the problem persists.
Perhaps the real problem is that I am trying to program the SAEF instead of designing it? (Please say no… 😉 )
Thanks!… Nico
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
Hi, Nico - Can you confirm that the Stand Alone Entry form works, if you copy and paste the example from the docs?
nanook's avatar
nanook
18 years ago
Hi Lisa,
Yes, I can. I am actually building my SAEF with code snippets from that example.
Thanks… Nico
Lisa Wess's avatar
18 years ago
Hi, Nico - since the SAEF itself works, I’m going to shift this down to the Plugins forum to get more focused assistance for you.
nanook's avatar
nanook
18 years ago
Hi Lisa,
We’ve found that if the plugin output is only used inside the entry_form, it works allright.
Probably, I’m getting bitten by the order in which everything inside EE is handled. Since I want to use this output inside a conditional, I think building the SAEFs by hand is the only way to go for now.
As a PHP programmer, that would be a bummer.
Thanks… Nico
Laisvunas's avatar
Laisvunas
18 years ago
Laisvunas's avatar Laisvunas
It seems that my_session plugin is mentioned neither on main plugins page nor on wiki plugins page.
Could someone to post download link for this plugin?
Thanks.
Mark Bowen's avatar
Mark Bowen
18 years ago
i think that it might be a plugin that Nico has created himself?
Best wishes,
Mark
nanook's avatar
nanook
18 years ago
Mark is right. It’s just a small plugin I am writing as the projects develops.
class My_session
    var $language_values=array('en', 'nl');
    var $language_output=array('English', 'Dutch');
    function My_session()
        if(empty($_SESSION['language'])){
            session_name('session_name_here');
            session_start();
            $_SESSION['language'] = $this->language_values[0];
Up till now, it’s just a small bit of code that starts a session and assigns a language session variable (‘en’ by default). A few functions exist to set and retrieve the language variable.
Nothing perfect, nothing big. Yet. 😉
I am used to working with PHP sessions, which I why I chose this route.
HTH… Nico
nanook's avatar
nanook
18 years ago
Oh, and just to make sure: that code snippet I posted is NOT the entire plugin… 😉
