segment_x does not work in allow_eecode?
tim594's avatar
tim594
18 years ago
tim594's avatar tim594
I thought the answer would be here (http://ellislab.com/forums/viewthread/36144/), but from what they say, segment variables should work in blog posts within allow eecode.
But Im doing it now, and it doesnt seem to work. whats strange is that THIS WORKS IN MY WEBLOG ENTRY:
{if segment_2 == "abc"}
segment works
BUT THIS DOESNT:
{segment_2}
Any ideas? Yea i’ve heard its bad practice to put eecode in blogs, but i want the customer to be able to edit it, without giving them template access.
tim594's avatar
tim594
18 years ago
ok. nevermind, it works now.
the problem was i had my {exp:allow_eecode} tags outside of my weblog:entry tags. i put them on the inside and it works.
