Cookie plugin not working
Michael Backes's avatar
Michael Backes
18 years ago
Michael Backes's avatar Michael Backes
Hi, I am able to set cookies using php, but I have some logic in EE tags that I wanted to pull the cookie out using the plugin, but I can not seem to get it to read or set any cookies. Does anyone know a trick to make the plugin work?
Thanks, Michael
Daniel Walton's avatar
Daniel Walton
18 years ago
Daniel Walton's avatar Daniel Walton
Post up some code, without that it’s hard to say where the cause of the problem stems 😊
Michael Backes
18 years ago
Well, I was pretty much using the default code in the plugin text:
In the page, I have an if statement, based upon if there is a segment_2. If there is one, then I go through, grab the appropriate blog and want to set the cookie with:
{exp🍪store name="mycoach" value="x” seconds=“3600"}
if there is no segment_2, then I want to use the cookie to get something out of the db using a query. So I pull the cookie using:
{exp🍪retrieve name="mycoach"}
I have tried a few different things to get the data out, but when that didn’t work, I went to the browser and went looking for the cookie at the time I set it. The cookie does not show up. If I create some php code in the page, then the cookie gets set. So I am thinking maybe it’s a problem with the plugin not working right. But there’s not a lot to the plugin, or the underlying php code. I am hoping that maybe there is a simple setting somewhere or a step I missed.
DEA's avatar
DEA
18 years ago
DEA's avatar DEA
Same issue here. The plugin sets the cookie fine, but can’t read it. In fact, I don’t even see any functions in the EE classes to get cookie values back out.
Jamie Poitra's avatar
Jamie Poitra
18 years ago
Jamie Poitra's avatar Jamie Poitra
There is no COOKIE specific retrieval function but the Input class should be able to retrieve a cookie like this:
$IN->GBL('cookie_name', 'COOKIE');
Cookies are notably domain specific though. A browser won’t give up one domain’s cookie to a page on another domain. You aren’t trying to do that are you?
Jamie
