FreeForm: Limiting entries question
sambo's avatar
sambo
18 years ago
sambo's avatar sambo
I am trying to select just the latest freeform entry (easy) BUT I need the selection also to be limited to a particular value of the entries.
So should it work to something like below? is_user_message=”1”? is_user_message is a field in the forms.
{exp:freeform:entries is_user_message="1" orderby="entry_date" sort="desc" limit="1"}
I also need a way to limit selection to form names (easy) BUT I need to do something like:
{exp:freeform:entries form_name="form1|form2|form|3" orderby="entry_date" sort="desc" limit="1"}
Is that possible? Doesn’t seem to work for me.
Best, Sammi
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
Hi, Sammi - I would recommend posting this over at Solspace’s support forums as Solspace is the author of this particular module. =)
sambo's avatar
sambo
18 years ago
Sorry about this. Stupid me 😉 Of course I should have done that.
However - I solved my problems by using the Query module.
Best, Sammi
