Does a module *require* a mod.mymod.php file?
Erin Dalzell's avatar
Erin Dalzell
18 years ago
Erin Dalzell's avatar Erin Dalzell
I have an idea for a module (I think it should be a module) that will allow the easy uploading of many images.
So all the functionality would be in the CP-side of things. There would be a few settings, then mostly a “GO” button to do the upload.
So, does a module HAVE TO have a mod.mymod.php file or can I just have an mcp.mymod.php?
Cocoaholic's avatar
Cocoaholic
18 years ago
Cocoaholic's avatar Cocoaholic
Hi Erin,
AFAIK it is not required. My REEOrder module only uses “mcp.reeorder.php” without any problems.
Erin Dalzell
18 years ago
Perfect thanks
(Goes off to write a module just for fun!)
