Tag Module: MySQL error
sigork's avatar
sigork
18 years ago
sigork's avatar sigork
Error Number: 1064 Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘s feet on the ground’)’ at line 1 Query: UPDATE exp_tag_tags SET clicks = (clicks + 1) WHERE tag_name IN (’keep one’s feet on the ground’)
http://www.solspace.com/forums/viewreply/1629/
Mod Edit: Moved to the Modules forum as this is about a third-party module.
sigork's avatar
sigork
18 years ago
The problem was solved by removing all cookies.
