Multi Relation - Gallery issues
mmjaeger's avatar
mmjaeger
18 years ago
mmjaeger's avatar mmjaeger
Hello,
I’m having two issues using the latest EE and the multi relation extension.
when selecting some gallery images in the blog entry, I somehow get a wrong path to the thumb image - I’m using the “{thumb_url}” in my template - using the normal related entries, the path to the image is fine. the multi relation extension creates something like this: “http://localhost/sites/dev_mmjaeger/dev_mmjaeger/images/gallery/usa_2003/04-07-118_s.JPG” vs. “http://localhost/sites/dev_mmjaeger/dev_mmjaeger/images/gallery/usa_2003/04-07-118_s.JPG” - as you can see, the “dev_mmjaeger” sub-dir appears twice.
the 2nd issue I’m having is when assigning some entries in the blog entry - update the entry - and then re-open/re-edit the entry, all the assingments are lost?
Hope somebody can help to get these issues solved.
thank you
