Help with Solspace's Form Helper Plugin
FrankJohnson's avatar
FrankJohnson
18 years ago
FrankJohnson's avatar FrankJohnson
Hi. I’m trying to use Solspace’s Form Helper plugin to create a stand alone edit form for my clients who own this site. I have been able to get the basic form working fairly easily, but I’m running into problems with the exp:form_helper:statuses tag.
Here’s the code I’m using:
{exp:weblog:entries weblog="newsletters" show_expired="yes" rdf="off"}
{exp:weblog:entry_form weblog="newsletters"}
<input type="hidden" name="entry_id" value="{entry_id}" />
{exp:form_helper:statuses entry_id="{entry_id}"}
<input type="radio" name="status" value="{entry_status}" {checked} /> {entry_status}
{/exp:form_helper:statuses}
<strong>Title</strong>
<input type="text" name="title" value="{title}" class="saeftextfield" maxlength="100" />
<strong>Image For The Article</strong>
(applies only to main weblog, newsletters and testbed; image should be 500 pixels wide by 100 pixels high)
<textarea name="{exp:form_helper:field_grabber field_name='entryimage'}"  rows="10" class="saeftextarea2" />{exp:form_helper:field_parser}{entryimage}{/exp:form_helper:field_parser}</textarea>
<input type="hidden" name="{exp:form_helper:field_grabber field_name='body' which='format'}" value="br" />
<strong>Body</strong>
<textarea name="{exp:form_helper:field_grabber field_name='body'}"  rows="10" class="saeftextarea" />{exp:form_helper:field_parser}{body}{/exp:form_helper:field_parser}</textarea>
<strong>Extended Text</strong>
<textarea name="{exp:form_helper:field_grabber field_name='extended'}"  rows="10" class="saeftextarea" />{exp:form_helper:field_parser}{extended}{/exp:form_helper:field_parser}</textarea>
<input type="hidden" name="{exp:form_helper:field_grabber field_name='extended' which='format'}" value="br" />
{/exp:weblog:entry_form}
{/exp:weblog:entries}
The problem is that the status checkboxes don’t show up at all on the form.
If I use the standard status drop-down menu from a stand alone entry form:
{status_menu}
Status
<select name="status">
{select_options}
</select>
{/status_menu}
I can get the drop-down menu to show up on the form, and I can close an entry from that form. However, if I go back to the same url (basedomainname/index.php/templategroup/saef/entryid) to see if I can open the entry again, I just get white space where the form should be.
My ultimate objective is to enable the client to use a stand alone edit form to close an entry and to open it back up again, but I would sacrifice the “open it back up again” if necessary.
Thanks in advance for any help anyone can offer - I really appreciate it. Let me know if you need more information or further explanation.
Frank
stinhambo's avatar
stinhambo
18 years ago
stinhambo's avatar stinhambo
You might be better off asking this on Solspace’s Form Helper Forum
FrankJohnson
18 years ago
Thanks Hambo - I had forgotten about the Solspace forums.
Frank
