Updating Textile plugin (urgent!)
lithiumdave's avatar
lithiumdave
18 years ago
lithiumdave's avatar lithiumdave
Hi all,
Would it be possible to update the Textile plugin to the latest revision? The current plugin is Textile 2.0.0 r2462 but is causing me big problems with unordered lists (a known issue confirmed on the Textile forums, that arises in conjunction with a version of PHP).
The issue is apparently solved with the latest revision (plain text version).
I’ve tried incorporating the new Textile class into the current pi.textile.php but no matter what I try I either get unprocessed text or a blank page.
I’m actually desperate to resolve this as I’ve just launched a high profile site today, on the same day my host decided to upgrade PHP - aaarrrrggghh!!!
Any help very (very, very, very) much appreciated 😊
lithiumdave
18 years ago
small bump
Greg Salt's avatar
Greg Salt
18 years ago
Greg Salt's avatar Greg Salt
Hi Dave,
Try this…. I’ve quickly jobbed it up so not tested it all. It’s running on a development site and seems to be ok.
Cheers
Dry
lithiumdave
18 years ago
YES!
Thank. You. So. Much.
Maybe this could replace the version in the main plugin download area? Working a treat for me here.
Thanks, thanks, and thanks again : )
Greg Salt's avatar
Greg Salt
18 years ago
No probs 😊
joann22's avatar
joann22
18 years ago
joann22's avatar joann22
Hi there, How’s the newer textlier2670 working for you guys? Any problems?
When I try to do this: “New in Textile 2.0 is the ability to store long ugly urls outside of the text you’re working in, and reference them with aliases of your choosing.”
It doesn’t seem to work with the old version Textile 2.0.0 r2462. (The entry field is set to Textile.)
I will give this textile2670 a try. Thanks for putting it together.
lithiumdave
18 years ago
The new version of the Textile plugin is working great for me, have it in action on 4 sites now with no problems whatsoever.
Leevi Graham's avatar
Leevi Graham
18 years ago
Thanks for the update! Any chance of getting this in the plugins directory?
lithiumdave
18 years ago
How does a plugin make it into the directory - is it a case of submitting and waiting?
Daniel Walton's avatar
Daniel Walton
18 years ago
Daniel Walton's avatar Daniel Walton
you must follow the ‘developer guidelines’ to a tee. Then submit, confirming compliance with guidelines.
simsa's avatar
simsa
about 18 years ago
simsa's avatar simsa
Hi, i am pretty new to EE but know Textile (i love Textile, it´s simple and fast) very well.
Now i like to use Textile for comments on a blog. I downloaded the new textile file from above and threw it into the plugin folder. I enclosed comments:
<textarea name="comment" tabindex="1" id="kommentarfeld">{exp:textile}{comment}{/exp:textile}</textarea>
This works… though i still get one pair of
tags in the comment textarea. How can i get rid of those?
BTW: Textile Reference Manual can be found on thresholdstate.com and the newer Textile Generator here: textile.thresholdstate.com
Jim Pannell's avatar
Jim Pannell
17 years ago
Jim Pannell's avatar Jim Pannell
I’ve downgraded my Textile version to 2640 now because I’m using PHP version 5.2.6, but I’m still having the same problems with lists.
Anyone have an update on this problem?
Cheers
Jim
