PHP, € and EE
pauljessup's avatar
pauljessup
18 years ago
pauljessup's avatar pauljessup
I’m getting strange symbols whenever I try and echo the Euro symbol (€) from PHP (in a plugin) it displays as garbage, yet it works fine in EE. Would this have something to do with the default characterset in php.ini, and if so, why doesn’t it effect EE (which I assumed, also uses PHP to render the templates…)
I wrote the plugin myself, and it just uses $r=”€” . $some_variable) and then returns it at the end of the function.
rather, here is a shortened example of what I’m doing:
function for_class() // would be EE tag exp:classname:for_class { $r=$r . ” some stuff to be displayed in the template”; $r=$r . “€” . $this->calculate_something; return $r; }
Note: this is just simplified, and showing a chunk of the actual function I’m using.
ExpressionEngineer's avatar
ExpressionEngineer
18 years ago
ExpressionEngineer's avatar ExpressionEngineer
Check your character set, perhaps it’s not correctly setup?
pauljessup's avatar
pauljessup
18 years ago
That’s what I thought, too, but wouldn’t that effect EE as well? I’ll check and change it and see if that works.
