Help on creating a module
pauljessup's avatar
pauljessup
18 years ago
pauljessup's avatar pauljessup
I’m new to EE but have about 6 years experience in PHP. I can do plugins fine, no problem. I’m using a plugin right now to create extended data for some stuff and storing it in a database, with tools that can be used to edit this data that can be called with EE tags.
Now, this works fine but I would love to make it a module and have the tools being used right in EE with EE’s own control panel. But, every time I try and make a module (editing the Fortunes example, or rather using it as a template) I get the same weird problem. When I click install, it doesn’t say it installs. But when I click on “install” again it asks me to uninstall it. It also doesn’t show the version number.
When I just upload the Fortunes example as-is, I have no problem. But the minute I rename it (I rename all the proper stuff, the file names, the folder, and the actual classes in the file (this I do with Scite’s find and replace utilities) and try that out I get the same error.
Paul Burdick's avatar
Paul Burdick
18 years ago
Paul Burdick's avatar Paul Burdick
Are you modifying the queries for exp_modules in modulename_module_install() method to have the new class name?
pauljessup's avatar
pauljessup
18 years ago
I think so. Let me check. If it is and still not working, I’ll post the contents of my install function
pauljessup's avatar
pauljessup
18 years ago
Here is the install function: function searchvi_module_install() { global $DB;
    $sql[] = "INSERT INTO exp_modules (module_id,
                                       module_name,
                                       module_version,
                                       has_cp_backend)
                                       VALUES
                                       'searchVi',
                                       '$this->version',
                                       'y')";
    $sql[] = "CREATE TABLE IF NOT EXISTS `exp_vidata` (  `id` int(11) NOT NULL auto_increment,  `bedrooms` int(11) NOT NULL default '0',  PRIMARY KEY  (`id`) ) ;";
    foreach ($sql as $query)
        $DB->query($query);
    return true;
Paul Burdick
18 years ago
That class name is not following the Developer Guidelines for Class Naming
pauljessup's avatar
pauljessup
18 years ago
That was it! Thanks. The actual class was named properly, but not the one mentioned in INSERT.
