Format pagination
mArzsmAn's avatar
mArzsmAn
18 years ago
mArzsmAn's avatar mArzsmAn
Is it possible to change the pagination variables in core.pagination.php with one of these hooks?
weblog_module_create_pagination
weblog_module_fetch_pagination_data
It seems that everyone just hacks the core file.
Jamie Poitra's avatar
Jamie Poitra
18 years ago
Jamie Poitra's avatar Jamie Poitra
mArsmAn,
If I’m looking at the code correctly that is the purpose of these hooks. Or a possible purpose at the least. It lets you create an alternate way of doing pagination. So how the pagination variables look and how they interact with your new pagination method would then be up to you. This would be generally preferable to hacking the core file especially since you wouldn’t then have to re hack it every time you upgrade or install a new build.
Jamie
