I had installed tinyMCE in the past in version 1.5 and was working fine. I made an install yesterday of the tinyMCE 2.1.2 and didnt work then i tried 2.1.1 and still not work. I cleared the cache as well.
I got already installed on another website tinyMCE with EE 1.5 the only sensible thing i can think of that 1.6 does not support the tinyMCE.
This is the error i get on the publish website :
Line : 1834 Char : 19 Error : Expectet ‘{’ Code : 0 URL : http://giorgoskalantzis.gr/admin/index.php?S=2c080de67b1b58db7d0f6b46c25ff03e75e6bc9a&C=edit&M=edit_entry&weblog_id=1&entry_id=8
maybe i m doing something wrong with 1.6 :(
thanks
Actually tiny MCE does not work in Firefox either. I don’t get teh same errors as I do in IE7.
I see all the icons, and when I try to use ibrowser I can select the image but when I try and click insert nothing happens, the pop up window closes and no image is inserted?? What is the deal all of a sudden tiny mce and ibrowser are having so much trouble with ee v1.6
I contacted my hostying and they have made no ugrades to the server
tiny works fine for me with 1.6, im using Tiny MCE Extension for EE (v.1.0.0)
here is my config from that tinymce extension:
mode : "exact",
elements : "field_id_2,field_id_6,field_id_11,field_id_15,field_id_20",
theme : "advanced",
plugins : "table,advhr,advimage,advlink,flash,paste,fullscreen,noneditable,contextmenu",
theme_advanced_buttons1_add_before : "newdocument,separator",
theme_advanced_buttons1_add : "fontselect,fontsizeselect",
theme_advanced_buttons2_add : "separator,forecolor,backcolor,liststyle",
theme_advanced_buttons2_add_before: "cut,copy,paste,pastetext,pasteword,separator,",
theme_advanced_buttons3_add_before : "tablecontrols,separator",
theme_advanced_buttons3_add : "flash,advhr,separator,fullscreen",
theme_advanced_toolbar_location : "top",
theme_advanced_toolbar_align : "left",
theme_advanced_statusbar_location: 'bottom',
theme_advanced_resizing: true,
extended_valid_elements : "hr[class|width|size|noshade]",
file_browser_callback : "ajaxfilemanager",
paste_use_dialog : false,
theme_advanced_resizing : true,
theme_advanced_resize_horizontal : true,
apply_source_formatting : true,
force_br_newlines : true,
force_p_newlines : false,
relative_urls : false,
cleanup_on_startup : true,
cleaup:truePacket Tide owns and develops ExpressionEngine. © Packet Tide, All Rights Reserved.
