Dirify plug-in attempt
Simon Cox's avatar
Simon Cox
18 years ago
Simon Cox's avatar Simon Cox
I have a request if someone could help out.
I would like to have a dirify plug-in / add-on - none is available and the normal suggestion is to build one yourself. I had a look at the Plug-in build documentation and it is way beyond my comprehension/skill levels - I can do design and html but I am as useful as cheese is to house building when it comes to real programming.
Thing is I do actually have the code needed - this is a conversion of the MT dirify function and Adam Kalsey produced a php version way back in 2004 - I thought that it woudl be a good starting point.
I had a look at how some other plug-ins are structured and tried to build a dirify plug in the same way but when I upload the file into EE the Plug in manager page either does not recognise it or worse fails to load the plug-in management page.
This is the code I have so far:
<?php
Bundled together as a plug-in By Simon Cox for his own use but the code is from Adam Kalsey - http://kalsey.com/2004/07/dirify_in_php/  and the copyright remains with him not me.
 File: pi.dirify.php
 Purpose: to strip output of spaces and change upper case charcters to lowercase to enable data to be used as a url.
e.g. Custom Field: SRN has data  ABC 01 001.
Dirify changes that into abc01001  so that it can be used in a text field and also in a url: src="/images/{SRN}.jpg" giving an out put of src="/images/abc01001.jpg" - useful if you have a large cataloge of products and images to go with them as the SRN number can be entered and the appropriate image is shown.
$plugin_info = array(
    'pi_name' => 'Dirify',
    'pi_version' => '1.0',
    'pi_author' => 'Simon Cox',
    'pi_author_url' => 'http://www.simoncox',
    'pi_description' => 'Dirification',
    'pi_usage' => Dirify::usage()
class Dirify {
    var $return_data;
/**  Dirify
function dirify($s) {
  $s = convert_high_ascii($s); ## convert high-ASCII chars to 7bit.
  $s = strtolower($s); ## lower-case.
  $s = strip_tags($s); ## remove HTML tags.
  $s = preg_replace('!&[^;\s]+;!','',$s);     ## remove HTML entities.
  $s = preg_replace('![^\w\s]!','',$s); ## remove non-word/space chars.
  $s = preg_replace('!\s+!','_',$s); ## change space chars to underscores.
  return $s;
 /* END */
//  Plugin Usage
function convert_high_ascii($s) {
     $HighASCII = array(
         "!\xc0!" => 'A',    # A`
         "!\xe0!" => 'a',    # a`
         "!\xc1!" => 'A',    # A'
         "!\xe1!" => 'a',    # a'
         "!\xc2!" => 'A',    # A^
         "!\xe2!" => 'a',    # a^
         "!\xc4!" => 'Ae',   # A:
         "!\xe4!" => 'ae',   # a:
         "!\xc3!" => 'A',    # A~
         "!\xe3!" => 'a',    # a~
         "!\xc8!" => 'E',    # E`
         "!\xe8!" => 'e',    # e`
         "!\xc9!" => 'E',    # E'
         "!\xe9!" => 'e',    # e'
         "!\xca!" => 'E',    # E^
         "!\xea!" => 'e',    # e^
         "!\xcb!" => 'Ee',   # E:
         "!\xeb!" => 'ee',   # e:
         "!\xcc!" => 'I',    # I`
         "!\xec!" => 'i',    # i`
         "!\xcd!" => 'I',    # I'
         "!\xed!" => 'i',    # i'
         "!\xce!" => 'I',    # I^
         "!\xee!" => 'i',    # i^
         "!\xcf!" => 'Ie',   # I:
         "!\xef!" => 'ie',   # i:
         "!\xd2!" => 'O',    # O`
         "!\xf2!" => 'o',    # o`
         "!\xd3!" => 'O',    # O'
         "!\xf3!" => 'o',    # o'
         "!\xd4!" => 'O',    # O^
         "!\xf4!" => 'o',    # o^
         "!\xd6!" => 'Oe',   # O:
         "!\xf6!" => 'oe',   # o:
         "!\xd5!" => 'O',    # O~
         "!\xf5!" => 'o',    # o~
         "!\xd8!" => 'Oe',   # O/
         "!\xf8!" => 'oe',   # o/
         "!\xd9!" => 'U',    # U`
         "!\xf9!" => 'u',    # u`
         "!\xda!" => 'U',    # U'
         "!\xfa!" => 'u',    # u'
         "!\xdb!" => 'U',    # U^
         "!\xfb!" => 'u',    # u^
         "!\xdc!" => 'Ue',   # U:
         "!\xfc!" => 'ue',   # u:
         "!\xc7!" => 'C',    # ,C
         "!\xe7!" => 'c',    # ,c
         "!\xd1!" => 'N',    # N~
         "!\xf1!" => 'n',    # n~
         "!\xdf!" => 'ss'
     $find = array_keys($HighASCII);
     $replace = array_values($HighASCII);
     $s = preg_replace($find,$replace,$s);
     return $s;
I am sure it probably transgresses some of the EE code standards that I read but to be honest I don’t understand them. Help would be appreciated as I am sure I would not be the only one who would like this.
TIA Simon
Ingmar's avatar
18 years ago
Ingmar's avatar Ingmar
Help me out here: Isn’t that, basically, what EE’s url_title conversion does? If so, you might be able to get, uh, inspired there.
Simon Cox's avatar
Simon Cox
18 years ago
Thanks Ingmar and yes that’s exactly what I would like to do but the url_title conversion takes the current URL title and converts that - I would like to do the same thing but to a custom field data instead - I cannot see how I could use the url_title to do this.
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
You could just use the find and replace plugin to replace spaces with underscores or hyphens or any combination thereof.
Simon Cox's avatar
Simon Cox
18 years ago
Thanks Lisa - this helps a lot. However I use an Apache server and the names of all the images are in lower case and the SRN product numbers are in upper case. I could go through and rename them with the appropriate upper case characters but I shudder at the thought of the RSI…
Derek Jones's avatar
Derek Jones
18 years ago
Ingmar’s right that ExpressionEngine’s url title creation method can handle this for you, with a bit more finesse than the PHP above. The only thing you need to add for your specific usage is a strtolower(). Follow the Plugin API instructions for creating your plugin file, but for the function use:
function Plugin_name($str = '')
    global $REGX;
    $this->return_data = strtolower($REGX->create_url_title($str));
Ingmar's avatar
18 years ago
I did not necessarily mean directly, but it should be possible to reuse EE’s code for that purpose.
EDIT: I see Derek has shown you a very elegant solution along these lines.
Simon Cox's avatar
Simon Cox
18 years ago
Thanks Derek! I will go through the Plug-in instructions and give it a go.
Simon Cox's avatar
Simon Cox
18 years ago
I have followed the Plug-In building instructions - and have built the file. It now shows up the the control panel so that s good progress. On the template though I am using the plug-in like this:
/images/{exp:dirify}{srn}{/exp:dirify}_215.jpg</a>
but the source code gives me this back:
/images/_215.jpg</a>
As you can see there is no srn number being returned.
I think I have implemented Derek’s code in the plug-in correctly:
class Dirify {
    var $return_data;
  function Dirify($str = '')
    global $REGX;
  //  Plugin Usage
  // This function describes how the plugin is used.
  //  Make sure and use output buffering
  function usage()
  ob_start();
Dirify allows you to change the characters of a custom field and use them in a url - as url_title does. This will allow one custom field to be used both for an SRN and the file name for a products image.
{exp:dirify} {your_custom_field} {/exp:dirify}
  <?php
  $buffer = ob_get_contents();
  ob_end_clean();
  return $buffer;
  // END
Just below this in the template I am running the same anchor code, but without the dirify, as a check - thats OK - its picking up the correct image values to display the image.
Derek Jones
18 years ago
Sorry, Simon, The code I used was just to demonstrate the use of the create_url_title() function, not as complete code. You will still need to use the $TMPL->tagdata to use in a template, otherwise the plugin will only function as a field formatting plugin. The complete function would be:
    global $REGX, $TMPL;
    if ($str == '')
        $str = $TMPL->tagdata;
Ingmar's avatar
18 years ago
Well, the whole plugin really can consist of three or four lines or so. Let’s see:
<?php $plugin_info = array ('pi_name' => 'Dirify', 'pi_version' => '1.0');
class Dirify { function Dirify() { global $REGX, $TMPL;
$this->return_data = strtolower($REGX->create_url_title($TMPL->fetch_param("input"))); }} ?>
Makes sense? Flesh out as desired. Needs a parameter named “input”, use like so:
{exp:weblog:entries}
{exp:dirify input="{title}"}
{/exp:weblog:entries}
or any other way to provide “input”.
EDIT: If you use Dereks approach, there’s no need for a paramter, but you need to open and close your plugin. Your choice.
Simon Cox's avatar
Simon Cox
18 years ago
Brilliant! Thanks eversomuch guys. I have it working and I opted for Ingmar’s input variation in the end. It is substituting spaces for underscores (as expected because that’s exactly what url_title does) but I am quite happy about that as I have a rename.exe utility somewhere that will allow me to rename the hundreds of images on the site I am rebuilding. This plug-in will make it much easier for the business users to input hundreds of products to the site - one less field to input into.
If anyone else needs this I will fill the forms and send it in but I am not going to claim any sort of authorship on it!
Again many thanks.
Ingmar's avatar
18 years ago
To be honest, I don’t think it merits it just yet.
Simon Cox's avatar
Simon Cox
18 years ago
I had a couple of minutes spare today and installed the Replace plug-in and then wrapped it around the dirify call giving me this:
img src="/images/{exp:replace find="_"}{exp:dirify input="{product_number}"}{/exp:replace}_215.jpg" alt="{title}"  width="215" height="215" >
And now I don’t even have to change any of the image names!
Lisa Wess's avatar
18 years ago
Very nice, Simon. Thanks for sharing that! As Victor said, I also hope you’ll submit it to the add-on database, or at the very least to our wiki plugin list =)
1 2
