Hello,
At the bottom of http://www.kevinevans.net/ I have an area where I am pulling from Flickr with the Flickr Tools plugin. It was working perfectly until recently…now I get an error there where the 2 photos should be. The code has not changed in the template. I was uploading with Aperture a new batch with Flickr export, toward the end there was some type of error and ever since then the photos are not being pulled.
Any idea what could be the problem?
Here’s the code I have in the template…
{exp:flickr_tools:get_recent group_id="40331280@N00" limit="2"}
<a href="http://{image_link}target=flickr" rel="noopener">/thumbnailer/phpThumb.php?src={image_url}&fltr[]=gray</a>
{/exp:flickr_tools:get_recent}But its been the same, so that should not be a problem.
This is my Flickr group I am pulling from…
Its a phpThumb.php error concerning a 302 error (moved temporary) and it seems the Flickr part would work if not using phpThumb on the pulled result. I’d try to track down if it would work without the phpThumb part as that would show if it is really related to the Flickr tools.
-Markus
